Re: How to deal with column for flooring
Originally Posted by
Legacy
Hmmmmm... you guys are giving some ideas.
I have a jamb saw, though a handsaw version, not the power version. Hadn't thought of thinking of the column base as a jamb. The way I see it, I could either 1) use the jamb saw using scrap flooring as a spacer to locate the jamb saw in elevation, as I have for the jambs) or 2) cut off the roundover which would result in a plain square base, then add a small quarter round molding to cover the gap.
I like #1 as it is probably the easiest overall except that on one side of the column, there isn't enough space for the saw to pass through. D'oh! I may have no choice but to do #2.
Removing the column is an absolute last resort thing which I don't want to get into... I can see it leading to a) having to get new columns, and b) an unexpected framing, drywalling and painting project!
Thanks for the suggestions guys.
Seems like you got the answers you need. Why don't you use the jamb saw on three sides and cut the round over off only on the side you can't access. A careful cut with a fine tooth saw and you could just fasten the off cut back in place afterward. Nobody will ever notice that small of a difference. Particularly since it's tucked into a tight place.
It's very unlikely that those posts are structural. #1 it's far easier for the framer to frame it in the standard manner then to use the posts to carry the load. #2, you said it was shimmed with wedges. That alone says it's not load bearing.
J.P. Rap Mount Hope Ont.
Carpe Ductum (Seize The Tape)
