Results 1 to 6 of 6
Thread: General 130 Planner Adjustment
  1. #1
    Join Date
    Jun 2006
    Location
    Coquitlam, BC
    Posts
    17
    Default General 130 Planner Adjustment
    I recently purchased a used General 130 planner at an auction. The planner had a 3 phase motor so this week-end I replaced the motor with a Leeson single phase motor and also installed a new motor starter. Today I ran the first piece of wood(cedar) through the planner for a test cut. The infeed roller seems to really grap the wood and tends to want to make the trailing end of the board jump up.
    I assume the in-feed roller needs adjusting but I also noticed that the roller is locked solid, when I pull up on it, even with the spring tension screws backed off all the way. Is this normal? I assumed that when I pull up on the roller I should be able to over come the spring tension and move the roller upward a small amount.
    All advise will be appreciated.
    Here is a pic of the planner.
  2. #2
    Default Re: General 130 Planner Adjustment
    sounds like the bed rollers are set too high.
    Hobby WW since 1972
  3. #3
    Join Date
    Nov 2007
    Location
    Canada's golf capital--Ottawa
    Posts
    1,231
    Maybe the original springs were replaced for more pressure---there should be some give in the roller--otherwise too much downpressure on the material.
    "Born 50 years too late"
  4. #4
    You suck Larry!
    Proper set-up is essential to get good performance. You can adjust your planner specifically for hardwood or softwood use, but most settle for middle ground.
    Here is a great article to help you understand and set up your "new" planner:
    http://wiki.owwm.com/Getting%20Peak%...rformance.ashx
    Hope this helps,
    Joseph
  5. #5
    Join Date
    Feb 2006
    Location
    St. Lazare, Quebec
    Posts
    41
    I bought a General 130 planer in 1981. Adjusting it was always a pain, until I used Robert Vaughan's technique after I read it in Fine Woodworking Magazine. (SEE: Joseph's post ) I made the dial indicator devices he described and followed his instructions. It made a big difference. The manual that General provided was never much help in adjusting this planer.
    I have run thousands of board feet of lumber through it over the years without it requiring any maintenance besides lubricating and adjusting. This machine is a testament to the high regard that General machines have.
    Garth
  6. #6
    Join Date
    Jun 2006
    Location
    Coquitlam, BC
    Posts
    17
    Thanks for the help. I downloaded that article and will use it to adjust the planer this week-end. In regards to the in-feed roller spring pressure, even though the rollers are difficult to move upward by hand pressure, they move easily with the roller height adjustment screws so I think all they require is proper height adjustment.
Similar Threads
  1. Spectacular new General planer *long* *PIC*
    By David in London in forum Power Tools
    Last Post: 03-06-2009, 10:48 PM
  2. General Warranty
    By Mark in Enfield NS in forum Power Tools
    Last Post: 06-15-2007, 09:01 PM
  3. Bandsaw 14" Delta vs General
    By agodin in forum Power Tools
    Last Post: 05-28-2007, 12:29 PM
  4. General International 50-220 Table saw
    By Rick in Brantford in forum Power Tools
    Last Post: 11-11-2004, 12:21 AM
  5. General Int. 15" vs. General 14" planer
    Last Post: 09-20-2001, 05:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
