Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Attaching 2X4 to brick wall
  1. #1
    Default Attaching 2X4 to brick wall
    Hi folks, I am starting a fence build and I have all the posts in the ground. I have been told that for the post beside the house wall, the solution is to attach a PT 2X4 directly to the house wall. This stud would hold the end of a short fence section attached to a gate.
    My question? How would I attach the 2X4? My thinking is to drill a hole into the 2X4 and tapcon it to the house. But, would I sink the tapcon into the mortar between the bricks? Is the mortar strong enough? Or would I sink it into the brick itself? Maybe it doesn't make any difference at all? Perhaps I just sink it wherever the hole happens to line up.
    Advice is appreciated.
    Thanks
  2. #2
    Join Date
    Mar 2007
    Location
    sarnia ont
    Posts
    8,589
    Real Name
    Steve Morris
    Default Re: Attaching 2X4 to brick wall
    tapcon into the middle of a brick
    my shop is a beaver lodge
    steve, sarnia, ont
  3. #3
    Join Date
    Mar 2008
    Location
    Toronto
    Posts
    127
    I second the middle, never into mortar
  4. #4
    Join Date
    Feb 2006
    Location
    Mount Hope Ont.
    Posts
    7,274
    Real Name
    J.P.
    Third.
    Don't over tighten. It's not hard to strip a tapcon out of brick. DAMHIKT
    J.P. Rap Mount Hope Ont.
    Carpe Ductum (Seize The Tape)
  5. #5
    Join Date
    Feb 2010
    Location
    Golden, BC, Canada
    Posts
    322
    I'm gonna buck the trend and suggest you do not mount the 2 x 4 or the fence to a brick veneer. It isn't structural.
    Find another method of adding the post to your fence-line.
    Please remember that free advise from the Internet is worth what you paid for it ...
  6. #6
    Join Date
    Apr 2006
    Location
    GTA (Greater Toronto Area)
    Posts
    6,807
    Blog Entries
    7
    Not sure if it applies to attaching for the purposes a fence as it does for a ledger for a deck, but I would be inclined to go thru the brick and screw into the joist or studs of the house. As was mentioned, brick is just a weather resistant veneer onto the structure of a house.
  7. #7
    Join Date
    Sep 2009
    Location
    St. Catharines
    Posts
    1,833
    While it may be a part of the house fore decorative purposes, calling the standard bricks veneer is a little deceptive and far fetched. Properly done brickwork is solid and it can easily hold the little bit of the fence. I wouldn't be worried about the strength of the brick at all. Not if the part of the fence attached to it is static, i.e. not a fence that swings back and forth.
    Introducing a hole into either the mortar joint or into the brick itself creates a increased chance of deterioration in frost zones. As water (eventually) enters the cracks and freezes in winter the brick starts to going south. The issue may be of course addressed by use of sealants, but many of those deteriorate too.
  8. #8
    Join Date
    Mar 2009
    Location
    Alberta
    Posts
    5,875
    Darius a single layer of brick is "Brick Veneer." Solid Brick construction hasn't been used for decades in residential construction.
    Personally I wouldn't fasten any of the fence to the house.
  9. #9
    Join Date
    Sep 2009
    Location
    St. Catharines
    Posts
    1,833
    Quote Originally Posted by Rusty View Post
    You know that houses are attached to that veneer, don't you?
  10. #10
    Join Date
    Apr 2006
    Location
    Posts
    6,807
    Blog Entries
    7
    A little extreme, but this video shows that brick is just veneer:
    http://toronto.ctv.ca/servlet/an/loc...TorontoNewHome
    Here's another one that recently happened in Montreal also:
    http://www.montrealgazette.com/news/...054/story.html
    Do you really want sniffer dogs trying to find your body in the rubble?
    Along similar lines, these guys in Vancouver are just plain stupid.
    http://www.youtube.com/watch?v=KKIZk...layer_embedded
    http://www.youtube.com/watch?v=GvWRK...layer_embedded
  11. #11
    Join Date
    Feb 2006
    Location
    Mount Hope Ont.
    Posts
    7,274
    Real Name
    J.P.
    Actually Kevin, That's structural. There is some supporting red iron in there but the brick wall looks to be over a foot thick. It's amazing half the building didn't come down with it. The wall inside is metal studs and is there only to hold the drywall. Had that wall been veneer, there would be a structural wall inside to hold the building up.
  12. #12
    Join Date
    Sep 2009
    Location
    St. Catharines
    Posts
    1,833
    Kevin, strangely, the first example is definitely a bearing brick wall. In the Vancouver example the bearing walls look like cinder blocks too me and the building is being demolished. Somehow I am not surprised that the circumstances shown in the clip caused the collapse. Honestly, are you?
    OP's house would collapse too if hit by heavy machinery, fence attached to the wall or not.
    What these examples show is that walls made of masonry can collapse for various reasons, and for the purpose of this thread, not much more.
  13. #13
    Join Date
    Mar 2008
    Location
    Toronto
    Posts
    127
    That's crazy to think a brick veneer wall will be compromised by lagging a fence to it, IMO.
  14. #14
    Join Date
    Mar 2009
    Location
    Alberta
    Posts
    5,875
    Quote Originally Posted by darius View Post
    I do! Did you know that the only attachment though is Brick ties?
    http://www.google.ca/imgres?imgurl=h...ed=0CC8Q9QEwBQ
    As for the fence attaching, I wouldn't do it because it's not necessary. Put a post in a hole right beside the house and tamp it in good or use concrete or whatever system you're using and forget about it. I have 2 - 6x6's within 20 inches of one another right beside the house. The first one is right against the house but not fastened to it. My 4 foot gate closes against the second one.
    Attached Images Attached Images
  15. #15
    Join Date
    Mar 2009
    Location
    Alberta
    Posts
    5,875
    It won't really be compromised unless you consider drilling an unnecessary hole in your brick is a compromise.
    I'm not suggesting for a minute that your fence will pull down your brick. Others might be suggesting that I dunno? All I'm saying is you don't need to do it.
  16. #16
    Join Date
    Jul 2008
    Location
    Penetanguishene, ON
    Posts
    2,750
    Blog Entries
    1
    Real Name
    Ummmm....Frank? :-)
    Lots of good discussion on this......but here's the *best* way to do it.
    There can be a surprising amount of force exhibited on a gate post, especially with a heavy or spring loaded gate, and most certainly over extended use. A single tapcon will transfer all of this force into a single point on the wall, not a good thing.
    Look at it this way....lets say you have a 15 lb gate....and that gate "hits" the post 200 times a year.....how long would the tapcon connection last if it were a 15 lb slege? You shouldn't rely on the brick veneer to absorb that shock....eventually your mortar will start to give/crack, which will allow water in. This will result in more damage through the freeze/thaw cycle.
    Dig down along the side of the house until you hit the footing (it will be a concrete ledge)
    Insert your post so it sits on the footing, measure and cut to length.
    Run a double bead of PL premium along the entire backside of the post, stick it to the wall and plumb.
    Pour in a couple bags of quick post,
    Backfill
    Done
    I dream of a better world, one where chickens can cross roads without having their motives questioned.
  17. #17
    Join Date
    Feb 2006
    Location
    Muir, near Woodstock,Ont.
    Posts
    4,195
    Quote Originally Posted by Ryan Shervill View Post
    Backfill
    Done
    Ryan... Are you suggesting that the post sit on the footing that is probably at least 8 ft below grade? seems a bit extreme. I have bolted the odd 2x4 to a brick wall using sleeve anchors and have not received 1 call back. I much prefer a post beside the wall and have it cemented into the hole and have never gone any deeper than 3 ft. I always tried to design a gate so the I could have a top rail between the two gate posts to avoid the post carrying the gate from leaning over.
    Brian
    " It is nice to be important but more important to be nice"
  18. #18
    Join Date
    Feb 2006
    Location
    Belgrave Ontario. Can
    Posts
    1,006
    Blog Entries
    6
    This is not rocket science This is all you need !
  19. #19
    Join Date
    Sep 2009
    Location
    St. Catharines
    Posts
    1,833
    Yeah, I saw those. When I worked as a bricklayer, I think ;)
    As for the depth of post holes next to the house, may depend on how old the house is. When it comes to deck footings the building code calls for digging all the way to the footing for houses that are less than a certain number of years old (forgot how many, prob. around 15 to 20). The issue is with the degree to which the back fill is considered to be compacted enough.
  20. #20
    Join Date
    Jul 2008
    Location
    Penetanguishene, ON
    Posts
    2,750
    Blog Entries
    1
    Real Name
    Ummmm....Frank? :-)
    Quote Originally Posted by Brian @ Muir View Post
    Brian
    8 FEET?
    I have yet to find the top of a footing deeper than about 4. 'course, things could be different in your neck of the woods, but I've never seen it.
Similar Threads
  1. Hanging a load on wall with metal studs. (?)
    By Ryan in Edmonton in forum Woodworking
    Last Post: 06-24-2010, 11:15 PM
  2. Help, Rotten wall behind brick, need ideas
    By scooby074 in forum Home Improvements
    Last Post: 03-23-2010, 03:51 PM
  3. Water water everywhere -insulated wall fix?
    By AL in Galt in forum Home Improvements
    Last Post: 01-27-2010, 05:20 PM
  4. Wall Unit
    By Stephan in St George in forum Woodworking
    Last Post: 10-03-2008, 02:32 PM
  5. Deck ledger on brick wall; beam sizes and spans
    By kapucin in forum Home Improvements
    Last Post: 03-21-2007, 11:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
