Results 1 to 6 of 6
Thread: Why is my meter reading 0 voltage across 2 hot legs of a double pole breaker?
  1. #1
    Join Date
    Nov 2009
    Location
    London ON
    Posts
    1,164
    Default Why is my meter reading 0 voltage across 2 hot legs of a double pole breaker?
    I'm installing a new 30 Amp 220V 1ph circuit for a table saw. I have a double pole breaker with 2 hots and a ground. The ground wire is continuous to the saw and grounded in the box.
    My meter reads 110v hot to ground on both legs but 0 across the 2 hots and my saw won't start. I have power going to the magnetic starter but she won't fire up.
    In the panel on the other side I have 3 220v circuits wired exactly the same and I get 220 across the hot legs on all three breakers and machines run fine on them.
    I swapped out the offending breaker for a brand new one, same deal. I put a second double pole breaker on the same side of the panel I'm wiring and I get 110v hot to ground but again I get 0v across the hots.
    I get 220 across the hots at the bus bar.
    Can anyone tell me what is going on?
  2. #2
    Join Date
    Jul 2008
    Location
    Penetanguishene, ON
    Posts
    2,754
    Blog Entries
    1
    Real Name
    Ummmm....Frank? :-)
    Default Re: Why is my meter reading 0 voltage across 2 hot legs of a double pole breaker?
    I'll betcha you have a Federal panel......am I right?
    If I am, You have both terminals sharing the same leg, so you'll have to move the breaker up or down one slot.
    I dream of a better world, one where chickens can cross roads without having their motives questioned.
  3. #3
    Join Date
    Nov 2009
    Location
    London ON
    Posts
    1,164
    Quote Originally Posted by Ryan Shervill View Post
    Yessiree I do. I'm going to try that right now. Thanks!
  4. #4
    Join Date
    Jul 2008
    Location
    Penetanguishene, ON
    Posts
    2,754
    Blog Entries
    1
    Real Name
    Ummmm....Frank? :-)
    Quote Originally Posted by dave_k View Post
    Believe me, you are not the first to run into this with Federal panels.....they are nice, but man can they be counter-intuitive to put breakers into.
  5. #5
    Join Date
    Nov 2009
    Location
    London ON
    Posts
    1,164
    I just moved everything down a slot and it works fine. Thanks again Ryan
  6. #6
    Join Date
    Jul 2008
    Location
    Penetanguishene, ON
    Posts
    2,754
    Blog Entries
    1
    Real Name
    Ummmm....Frank? :-)
    Awesome Glad it was an easy fix.
    Ryan
Similar Threads
  1. Note! This Is Required Reading For All Men!
    By StephenL in forum Off Topic
    Last Post: 02-15-2010, 09:16 PM
  2. Some interesting reading
    By Pete in Welland in forum Turning
    Last Post: 10-14-2008, 05:37 AM
  3. What are you reading?
    By J.P. Rap in forum Off Topic
    Last Post: 05-23-2008, 11:51 PM
  4. Kindergarten reading bench
    By Woodwreck in forum Woodworking
    Last Post: 01-28-2008, 10:05 PM
  5. Reading material
    By danpower in forum Woodworking
    Last Post: 12-05-2006, 12:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
