Re: Lathe Spindle sizes
the odd thing is that it costs money to machine that spindle down to one inch from the blank which was somewhat bigger than 1 1/4, in fact the blank was bigger than the largest diameter on the spindle. so the center section was turned down to accomadate the pulley set. the smallest pulley size is chosen by the required max speed of the machine and the spindle has to accomadate that
the spindle in a beaver 3400, is 7/8 od from the threaded end to the shoulder for the outboard bearing where it drops to 3/4 but there also a shoulder for threaded stuff to stop against, im guessing 1 1/8 in diameter, so of course the billet blank had to be at least 1 1/8 od
the spindle diameter inside the headstock has to be small enough to accomadate the smallest drive pulley which has to be big enough to house a set screw and the woodruff key
my shop is a beaver lodge
steve, sarnia, ont
