Results 1 to 12 of 12
Thread: maggi power feeder?
  1. #1
    Join Date
    Sep 2006
    Location
    Edmonton
    Posts
    2,607
    Default maggi power feeder?
    I picked up a shaper a while ago (that I restored) and haven't used yet.
    There is a maggi power feeder (steff 2034 with 4 rollers) for sale at $550 locally which seems to be in good condition. I think it's a 1HP (or at least 1/2HP)
    I know they are good feeders but is this a good price? it appears they sell for over $1k new.
    I will most likely keep using my router more often but I might decide to build an entry door and kitchen cabinet for a new house, in which case the shaper could be quite useful. I am thinking worst case I could sell it for about the same price.
    Comments/suggestions? TIA
  2. #2
    Join Date
    Dec 2007
    Location
    California
    Posts
    2,694
    Real Name
    Steve
    Default Re: maggi power feeder?
    Attached shows it as 3 rollers $1,000 FYI
    http://forum.canadianwoodworking.com/image.php?type=sigpic&userid=12450&dateline=127309  6828 Wood Wreck - Structural framing specialist.
  3. #3
    Join Date
    Feb 2006
    Location
    Burlington
    Posts
    2,795
    Real Name
    Mark Rose
    I have almost the same model but mine is the 2048. That seems like a good price from what I have seen at auction, providing everything is in good shape and the rollers have not gone hard or badly worn. They are a lot nicer than the Asian Comatic units, I have the baby feeder as well on my router table.
    Cheers, Mark
    Today's mighty oak is just yesterday's nut, that held its ground.
  4. #4
    Join Date
    Sep 2006
    Location
    Edmonton
    Posts
    2,607
    Quote Originally Posted by Woodwreck View Post
    Thanks. I know there are 3 and 4-roller models of this machine. The one I'm talking about is probably the one on page 6 of the following:
    www.high-tech.ie/hitechmachinery/Files/Powerfeeds_MAGGI_STEFF.pdf
  5. #5
    Join Date
    Feb 2006
    Location
    Muir, near Woodstock,Ont.
    Posts
    4,192
    I think that is an excellent price. I have a 1/4 hp Toolex ( co matic ) and a 4 wheel 1 hp Delta and on a shaper it moves you into a different world and a whole lot safer especially on raised panels. Climb cutting done safely and no tear out. Steff has an excelent reputation but I am also very happy with the one I have. I have the 1/4 hp mounted on a riuter table and it is fantastic. Much better quality mouldings as you have even down pressure and a constant feed rate.On the router table I make the odd door and with a PC 7518 router and powe feeder everything is done on one pass.
    Brian
    " It is nice to be important but more important to be nice"
  6. #6
    Join Date
    Oct 2009
    Location
    Toronto Ontario
    Posts
    2,691
    Real Name
    A.B. Normal
    That's a nice feeder, I'd purchase it.................Regards, Rod.
  7. #7
    Join Date
    Sep 2006
    Location
    Edmonton
    Posts
    2,607
    Thanks. Looking at the picture closely, it appears to be a 3-roller only (even though the ad. says 4-roller).
    http://edmonton.kijiji.ca/c-buy-and-...AdIdZ382976424
    I'm going to take a look at it later this evening and see if I can make a deal.
  8. #8
    Join Date
    Jul 2009
    Location
    Buck Lake Alberta
    Posts
    1,504
    Real Name
    Mike Delyster
    Looks like its all there, I would grab it if I where you. They don't come up used around here very often.
    Mike
  9. #9
    If it's in decent shape, I'd be on it like a... (can't say that here)
  10. #10
    Join Date
    Feb 2006
    Location
    Burlington
    Posts
    1,621
    What voltage is the unit? It should last 2 lifetimes. Those units are designed to be run for 100,000 hours. I think the price was excellent.
  11. #11
    Join Date
    May 2009
    Posts
    257
    Hi mreza,
    The Maggi 2034 is a 3 roll four speed feeder new around $1100. The 2044 would be a four roll four speed machine and the 2048 is a four roll eight speed machine. All run a 1 hp motor. Be sure on the power though as most of the Maggi machines older are three phase power.
    We do stock brand new Maggi feeders as our first shipment just arrived in Canada. We are currently jumping threw hoops trying to get CSA to approve them.
    We also stock a 2033 model in single phase with eight speeds for $995.00. It is very similar to the 2034/2038 model except the stand and column are a little lighter size.
    The eight speeds are better for lower hp shapers because they have lower speed capabilities. Good if you need to take multiple passes. They also have faster speeds.
    The price is good on the used one you mentioned if it is in single phase power and the wheels and unit itself is in good shape. New wheels are about $40 to replace.
    Cole
    Canadian Woodworker Ltd
  12. #12
    Join Date
    Sep 2006
    Location
    Edmonton
    Posts
    2,607
    Thanks to all. I was going to go there tonight but after talking to the seller had to reschedule it for tomorrow as he doesn't have 220 power to test run it.
    I suspected it is 3 roller (based on pic) and the seller now confirmed he made a mistake and it is a 3 roller model. Will report back tomorrow.
Similar Threads
  1. Using a power feeder on a jointer
    By Jack from Northen Quebec in forum Power Tools
    Last Post: 01-18-2011, 04:55 AM
  2. Fishing for a Power Feeder 1HP, 1PH, 230V (RESOLVED)
    By Albert in forum The Swap Meet
    Last Post: 12-01-2010, 08:44 PM
  3. Steff 38 Power Feeder - $350 (SOLD)
    By Steve in Ayr in forum The Swap Meet
    Last Post: 06-01-2010, 02:05 PM
  4. Proper usage of Power Feeder
    By Todd in forum Power Tools
    Last Post: 04-11-2009, 12:55 PM
  5. Info on Power Feeder Needed
    Last Post: 01-20-2008, 12:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
