Results 1 to 10 of 10
Thread: Saw/Jointer Combo Project
  1. #1
    Join Date
    Sep 2011
    Location
    Kelowna, BC
    Posts
    74
    Default Saw/Jointer Combo Project
    My buddy has been looking for a TS recently, so while browsing Kijiji trying to find him one, I spotted something I liked the look of in the form of a tablesaw/jointer combo for a very reasonable price. I went to look at it and the guy said it was in the way and needed it gone asap, so I quickly went home and returned with tools so I could strip it and get it in my car.
    In my haste I forgot to take some photos of it assembled, but it looks the similar as the one in the first photo below, apart from the jointer being a Beaver.
    Everything looks to be there and in good order apart from the TS blade guard which is missing - it even comes with the molding cutter head. The saw is 10" and badged as a Delta serial no. 78-8507. The jointer is 61/2 x 42" and badged as a Beaver 4800. The original fence, mitre guage and dust chute are also present and in good condition, as is the mounting table, but the original dual motor has be changed for 2 singles.
    I'll re-assemble it and take some photos before I start the resto on it, but for now you can have a couple of it stripped into car sized peices.
    Has anyone seen one of these before, and are they worth much?
  2. #2
    Join Date
    Mar 2007
    Location
    sarnia ont
    Posts
    8,602
    Real Name
    Steve Morris
    Default Re: Saw/Jointer Combo Project
    interesting combination!!
    first the tablesaw is a tilt table delta, 10 inch i think you told me. the jointer is actually a rockwell 37-220 rebadged beaver and made in guelph
    beaver, delta and rockwell were all interrelated after 1954, so there was lots of "crossover" product if in fact your combo was sold origanally as you now have it
    tilt top tablesaws kinda disappeared in north america in favour of the tilting arbour, on a tilttop the table tilts and goes upand down for blade adjustments. the big advantage was that the motor could be rigidly mounted on those saws
    the beaver 4800/rockwelldelta 37-220 is a well respected machine and a nice score. rockwell made them for decades with very few changes. the beaver version as far as i know, is identical. it replaced the hugely complex beaver 3800 shortly after rockwell bought beaver in 54
    the origanal combo machine as shown in the pic from vintage, shows the rockwell flare leg stand and a double shaft motor to drive both machines
    post some more pics especially the badges, stand and motor
    my shop is a beaver lodge
    steve, sarnia, ont
  3. #3
    Rich- These were good heavy duty saws which they continued to sell for sometime after the development of the Unisaw. I have seen many of these combos for sale in the $150 to $200 range, some even lower. It would be worth more with the original motor. As witnessed by your first pics it will fix up nicely. Just be carefull with the casting for the tilt mechanism, they are notoriously brittle and are prone to cracking and loosing teeth. Parts including a replacement guard are not that hard to find although they can be pricey.
    As for the combo I suspect it was not original as the saw predates the jointer by several years. This may be the reason you have two motors.
    Major drawback of the saw can be the tilting table but that depends on how much bevel cuttiing you do. All in all a nice find.Good luck with it.
    By the way,I thought you moved.(hint)
  4. #4
    Join Date
    Sep 2011
    Location
    Kelowna, BC
    Posts
    74
    Haha, sorry Gerry - is that better?!
    The table looks the same as the one pictured, apart from the wheels, mine doesn't have any. I've had a look through the ones posted on OWWM and there seem to be quite a few combos on there that look similar. I'll get it back together this week and get some decent photos.
    The guy wanted $75, I offered him $25 and we settled on $30, I'm happy with that!
  5. #5
    Join Date
    Jul 2009
    Location
    Buck Lake Alberta
    Posts
    1,518
    Real Name
    Mike Delyster
    Thought you might like these, a couple of combo machines.
    Mike
  6. #6
    Join Date
    Mar 2007
    Location
    sarnia ont
    Posts
    8,602
    Real Name
    Steve Morris
    30 bucks for a nice saw and a beaver 4800(aka 37-220)?
    thats worthy of a big "YOU SUCK"!!
    steve, sarnia, ont
  7. #7
    Quote Originally Posted by Richardo View Post
    WOW! I'd be happy too.
  8. #8
    Rich - This combo has a jointer that appears to be of the same vintage as yours. Looks like I could be wrong yet again.
    http://vintagemachinery.org/photoind...il.aspx?id=171
  9. #9
    Join Date
    Mar 2007
    Location
    sarnia ont
    Posts
    8,602
    Real Name
    Steve Morris
    Gerry, that sure looks like the 42 inch 37-220, on a combo machine
    it does seem odd though that a beaver 4800 jointer wound up on a combo machine with a delta tilt top saw unless of course somebody(even a dealer) changed it
    i wonder if the tilttops were ever made in guelph, i didnt think they were
    my theory is that a customer wanted a combo with a longer jointer, so the dealer switched them or of course a previous owner did later on
    steve, sarnia, ont
  10. #10
    Join Date
    Oct 2010
    Location
    Barrie, Ontario
    Posts
    3,620
    Real Name
    Jarrett
    I guess if it was available as a single sku from the manufacturer, it should be considered a "combo". However I'm wrestling with the classification seeing as its basically two completely separate machines (available individually) sharing a table and being ran off a single motor.
    When I think "combo" I think of something like Crescent's Universal Woodworker, or the like.
    At any rate, it's going to be nice to see something a little different being restored on the forum. I'm looking forward to following along.
    ...Join us at the first annual GCRJF this July 6th&7th...
    .................>>Click here to find your way to the GCRJF<<...................
Similar Threads
  1. Replies: 16
    Last Post: 04-14-2012, 01:08 PM
  2. Makita planer/jointer combo
    By James S in forum Power Tools
    Last Post: 04-05-2011, 09:00 PM
  3. Any regrets with a combo jointer/ planer ??
    By OttawaP in forum Power Tools
    Last Post: 03-28-2011, 12:35 PM
  4. rojek combo jointer/planer
    By schark in forum Power Tools
    Last Post: 06-24-2009, 12:47 AM
  5. Jet 10" Jointer/Planer combo
    By Al in Toronto in forum Power Tools
    Last Post: 05-31-2009, 08:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
