Results 1 to 12 of 12
Thread: Bosch door hinge template
  1. #1
    Join Date
    Mar 2006
    Location
    Miramichi N.B.
    Posts
    54
    Default Bosch door hinge template
    I am a bugger for punishment ! I bought a used Bosch door hinge template to help hang about 10 solid doors in our new house . When I asked about guides and cutters the guy said any would work . Well mine don't !
    I guess my problem is which guide and cutter to buy . The guide from Bosch is no longer available . If anyone uses this jig can you tell what cutters and guides you use ?
    Thanks.
  2. #2
    Join Date
    Dec 2007
    Location
    California
    Posts
    2,694
    Real Name
    Steve
    Default Re: Bosch door hinge template
    Bosch lists several parts - are you referring to the defacto 1 3/8" guide bushing set http://www.boschtools.com/Products/T...spx?pid=RA1125 - is that what you mean by "guides and cutters?" See also Bosch reference to other manuf. Part numbers will help. Thx
    http://forum.canadianwoodworking.com/image.php?type=sigpic&userid=12450&dateline=127309  6828 Wood Wreck - Structural framing specialist.
  3. #3
    Join Date
    Mar 2006
    Location
    Miramichi N.B.
    Posts
    54
    When you buy the jig a template guide and cutter are included . When I contacted Bosch they said that they have no stock or replacement parts for the jig , so here I am looking for something that might work.
  4. #4
    What is the size of the space on the jig? There should be a standard bit/template guide combo that will work. I saw a review on a Bosch hinge template that said any router with a 5/8" collar and 1/2" bit will work. If the jig space is 4 5/8", then the 5/8 and 1/2 bit combo will work (for a 4 1/2" hinge)
  5. #5
    Join Date
    Mar 2006
    Location
    Miramichi N.B.
    Posts
    54
    My Makita router base is too big and hits some adjustment screws and my Craftsman guides are too short . I was hoping that someone knew the combination to help me out . I have a 5/8 guide guide for my Makita but the base is to big .
  6. #6
    Join Date
    Mar 2009
    Location
    Alberta
    Posts
    5,874
    I've had the Bosch Jig [if it's this one; http://www.amazon.ca/Bosch-83038-Del.../dp/B0000224KW ] for years and years. All you need is a deeper than normal guide bushing and any properly sized router bit will work with it. They are easily found at tool stores.
    "Do it Right!"
  7. #7
    Join Date
    Mar 2007
    Location
    On the shores of Georgian Bay
    Posts
    3,527
    Real Name
    Ryan
    At work my boss has the carey jig, now from LV. The bosch looks like it's the same idea, yes? With the carey jig, you can use just any router bit with a bearing guide, and just ride the bearing around the inside of the template. Can the bosch not work in the same way? What am I missing?
  8. #8
    Join Date
    Mar 2009
    Location
    Alberta
    Posts
    5,874
    Lee valley has had that one or something very similar for years. Porter cable made a good one too.
    What you're missing is deeper. The Bosch guide requires a deeper guide bushing. The PC one does not. Don't know about the LV one. Then don't forget you need the right amount of offset between the guide and the cutter and some hinges have a couple of different radii on the corners.That negates the use of just any router bit!
    "Do it Right!"
  9. #9
    Join Date
    Mar 2006
    Location
    Miramichi N.B.
    Posts
    54
    That is the problem , the 5/8guide works but the router base is too big . I am going to put in an order to LV tomorrow so that should do it . Will still have to work something out ( router base ) but will get 'er .
  10. #10
    Join Date
    Mar 2007
    Location
    Posts
    3,527
    Real Name
    Ryan
    Quote Originally Posted by Rusty View Post
    if you read the LV description, they note that it was formerly made by the carey company, but now that company has gone bankrupt. To keep the jig on the market, LV bought the plans and production jigs and now manufactures it themselves. That's what I meant by "now from LV." Not that it is only just now being carried by them, but that it is now manufactured by them, and not by the carey company.
  11. #11
    Join Date
    Mar 2009
    Location
    Alberta
    Posts
    5,874
    You must have an awfull big router Fred.
    "Do it Right!"
  12. #12
    Join Date
    Mar 2009
    Location
    Alberta
    Posts
    5,874
    Gotcha,,,,,,,
    "Do it Right!"
Similar Threads
  1. Replies: 0
    Last Post: 02-06-2011, 06:55 PM
  2. Kitchen Door Hinge Choice
    By HorseshoeHobby in forum Woodworking
    Last Post: 02-04-2010, 12:51 PM
  3. Replies: 5
    Last Post: 12-20-2009, 01:02 PM
  4. Door Hinge Dilemma
    By Walter in forum Woodworking
    Last Post: 11-01-2009, 06:58 PM
  5. Bosch 1619evs template guide
    By Mike in forum Power Tools
    Last Post: 02-05-2005, 07:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
