Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: making a proper work bench
  1. #21
    Join Date
    Jun 2012
    Location
    Timmins, Ontario, Canada
    Posts
    1,031
    Real Name
    Andrew J. Coholic
    Default Re: making a proper work bench
    Quote Originally Posted by kerfin View Post
    Remind me again why workbench designs sometimes have an asymmetric overhang like Andrew's? (Meaning the base is not centered under the top looking at it from the long side.)
    The front vise ( on the left) needs 20" or so clearance and for a fairly deep portion of the underside, while the tail vise does not ( it only needed 7" clearance on the side)
    Andrew J. Coholic
    Joe Coholic Custom Furniture Ltd.
    Timmins, ON
  2. #22
    Join Date
    Apr 2012
    Location
    Toronto, ON
    Posts
    203
    Real Name
    Arcady Genkin
    What an awesome bench, thanks for sharing!
    Andrew, I see that the bench sits on eight (?) furniture levelers (like this?). Don't they make the bench a bit less stable?
  3. #23
    Join Date
    Jun 2012
    Location
    Posts
    1,031
    Real Name
    Andrew J. Coholic
    Quote Originally Posted by agenkin View Post
    Yes, I have two adjustable levelers per foot. My cement floor is fairly uneven, and I wanted the ability to level off the bench to have it at the same height as my 10" table saw (34"). Once I have it in the exact place I will leave it, I can make a maple pad that will replace the levelers. However, with two per foot (ie the bench is sitting on 8 of them) there is no issue with stability/sturdiness.
    AJC
    Andrew J. Coholic
    Timmins, ON
  4. #24
    Join Date
    Oct 2009
    Location
    Sarnia, ON
    Posts
    525
    Andrew, have to agree with everyone- very nice bench and built lightning quick!
  5. #25
    Join Date
    Mar 2007
    Location
    Winnipeg
    Posts
    934
    Thanks for posting this - I really like your bench and thanks for posting the photos. It loooks like a pretty straighforward uncomplicated build and just what I am looking for Thanks again.
    Nothing is ever as straightforward as it seems.
    Glenn from Winnipeg
  6. #26
    Join Date
    Feb 2010
    Location
    Washago, ON
    Posts
    955
    Andrew,
    Just curious - Did you base you work off a plan or did you just draw up what you wanted ?
    The bench does look great.
    terry
    "I am on a drug. It's called Charlie Sheen"
  7. #27
    Join Date
    Jun 2012
    Location
    Posts
    1,031
    Real Name
    Andrew J. Coholic
    Quote Originally Posted by NuggyBuggy View Post
    Andrew,
    terry
    Size was based on what fit in the space I had to work with. The height is the same as my 10" table saw (35") as I will use the work bench to support long stock when I need to.
    The design, well, I have used the "two slab with a center trough" in the past and it seemed like a good idea for me. The base was sized to accomodate the Lee Valley vises. That's about it... I ended up buying a book on bench design, but I had the bench finished before the book even made it to my house ;)
    So far, its working well for me. I use it daily for some thing or another. The vises are very nice as well.
    AJC
    Andrew J. Coholic
    Timmins, ON
  8. #28
    Join Date
    Feb 2006
    Location
    Pickering, Ontario.
    Posts
    2,799
    Nice bench. That should last you the duration.
    Having space to work on large projects like the bench is a great advantage most of us don't have, let alone large assembly table etc.
    I agree that a 'shop tour' is in order when time permits.
  9. #29
    Join Date
    Jun 2012
    Location
    Posts
    1,031
    Real Name
    Andrew J. Coholic
    Quote Originally Posted by Rick Thom View Post
    http://forum.canadianwoodworking.com...to-have-a-look
    Andrew J. Coholic
    Timmins, ON
  10. #30
    Ok guys, everyone should have a look at Andrew's shop! Well worth it. I'm still wiping the drool off.
    Andrew, I'll be sure to look you up if I ever get to Timmins again.
    Claude
    “Small minds discuss people, average minds discuss events, great minds discuss ideas.”
    Admiral Hyman Rickover
  11. #31
    Join Date
    Jun 2012
    Location
    Posts
    1,031
    Real Name
    Andrew J. Coholic
    Quote Originally Posted by Claude in Kitchener View Post
    Certainly, I'd be happy to show you the shop!
    Andrew J. Coholic
    Timmins, ON
Similar Threads
  1. Work Bench Top
    By Jerome in forum Woodworking
    Last Post: 07-23-2011, 10:10 PM
  2. Another tread on making a work bench
    By matt.mackinnon in forum Hand Tools
    Last Post: 07-22-2009, 07:04 PM
  3. Work bench top
    By Paul/Sarnia in forum Shop Related Discussions
    Last Post: 02-09-2007, 12:52 PM
  4. Work Bench
    Last Post: 02-02-2007, 11:40 AM
  5. Yet another Work Bench !
    By Edward G. Burlington in forum Shop Related Discussions
    Last Post: 11-19-2006, 11:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
