King Canada lathe model no. KWL-1218VS
  • Filter
  • Time
  • Show
Clear All
new posts
  • King Canada lathe model no. KWL-1218VS
    Greetings
    I purchased one month ago a King Canada lathe model no. KWL-1218VS
    The problem I am facing know is that the machine tailstock would slip after tightening the piece ( see 1+ 2 pictures , with red circle around the issue)
    I think this is related to the piece underneath the tailstock that hold it in place (picture 3) , it is not wide enough to provide better tightening
    Is this normal with lathes or I have to contact the manufacturer , appreciate your feedback , thanks
    Picture 1+ 2 ( Tail stock slipping)
    Picture 3 (underneath piece)
  • Thread Continues Below...
  • #2
    Re: King Canada lathe model no. KWL-1218VS
    Photo upload didn't work unfortunately, please see this thread for instructions.
    • #3
      I just looked at the manual and as I suspected, there is a round thick washer like piece that has to keep the tailstock from moving, the same under the banjo.
      I had a Delta Midi Lathe LA200 that had the common round disk under the tailstock, and it did let the tailstock creep, so I made a simple rectangular plate for it, shown in the two pictures here.
      The problem with the round disks is that there is just a very small area to prevent the slipping, even when adjusted properly, it is something like these two here (l l) show, if you imagine that the two straights are the lathe bed, there is a very small area under it (l l), anyway I just used a ¼” piece of flat stock, as I had it, though a bit thicker might be better, mine did work just fine.
      Click image for larger version  Name:	Tailstock plate.jpg Views:	0 Size:	93.9 KB ID:	1280717Click image for larger version  Name:	Plate added to tailstock.jpg Views:	0 Size:	117.5 KB ID:	1280718
      Have fun and take care
      Leo Van Der Loo
      • #4
        Like Leo I've made similar clamp blocks. I used 1/2" aluminum plate because I could cut it out with my table saw. It worked pretty good although it was a bit stickier than steel. You can also buy blocks from Lee Valley. https://www.leevalley.com/en-ca/shop/tools/hand-tools/turning-tools/101330-clamp-blocks-for-steady-rests-for-spindles-and-bowls
        • #5
          Here's my fix for breakup of cast iron clamp mechanism on Craftmaster. Got idea from Vintage Machinery schematic of 1967 Rockwell / Delta 12" lathe showing a 5/16" U bolt mechanism. 1/4" plate is from a piece of steel laying around. Small 1/8" thick piece, riveted in place, is to guide block between bed ways. Works well. Also added an extension to lever mechanism.
ID:	1280753Click image for larger version
ID:	1280754Click image for larger version
ID:	1280755Click image for larger version
          • #6
            Originally posted by Mosarbo View Post
            Greetings
            Welcome to the forum. You made need to make a few posts before you will be allowed to upload pictures?
            • #7
              Click image for larger version  Name:	49443560831_d1774af5b9_k.jpg Views:	0 Size:	541.9 KB ID:	1280753Click image for larger version  Name:	49443786092_16f1c2e1b2_k.jpg Views:	0 Size:	590.9 KB ID:	1280754Click image for larger version  Name:	49443785847_e1b8131107_k.jpg Views:	0 Size:	607.7 KB ID:	1280755Click image for larger version  Name:	49782626396_329b3017e5_k.jpg Views:	0 Size:	773.4 KB ID:	1280756
              As they say, whatever works for you, but why did it break in the first place ??, and I would suggest that round waster plate, where when it wasn’t holding the tailstock secure, extra leverage was used, now that the washer plate has been replaced by a rectangular plate, the extra leverage isn’t needed anymore.
              If I had to do the repair, I would’ve made a new ring for the broken one and replaced the washer plate for a rectangular plate.
              If you are happy with your fix than that’s all that count, happy turning
              Leo Van Der Loo
              • #8
                Thanks for all who provided solutions , it really helped me tackle the issue
                • #9
                  Leo:
                  "If I had to do the repair, I would’ve made a new ring for the broken one and replaced the washer plate for a rectangular plate."
                  Fabricating a ring wasn't possible in this old codger's hands and the u-bolt solution had it fixed in an hour. I am more than happy!
                  If anyone's interested here's the '67 Delta Rockwell manual with pic and schematic of tailstock u-bolt clamp that I got idea from. It doesn't seem to be a design that's carried on so I do wonder re longevity.
                  vintagemachinery.org/pubs/698/6850.pdf
                  Doug
                  Working...
