General lathe parts suppliers?
  • Filter
  • Time
  • Show
Clear All
new posts
  • General lathe parts suppliers?
    I have a friend that bought a General 160 that apparently was a mistreated school lathe. The outboard headstock spindle threads are pooched, look like they were graunched with vice grips. Does anyone know of a source of parts for General lathes?
    Pete
  • Thread Continues Below...
  • #2
    Re: General lathe parts suppliers?
    Are the threads so bad that they can not be cleaned up with a file? That would be my first stab at trying to fix it. Short of finding a parts lathe it's going to be tough to get a spindle. I believe that the pitch on the outboard side is 1 1/8 8. A left hand die might also repair the damage enough to make it work. They are not cheap but available https://www.ebay.com/itm/Professional-Hexagon-Rethreading-Dies-2-x-1-1-8-UN-LH-Carbon-Steel-2118HXD/352333028673?hash=item5208af5d41:g:~toAAOxy039TKJ~ f
    • #3
      I think that spindle thread spec is for the General 260 and the 160 is 1-8TPI on both ends, LH on outboard of course.
      Best to check what you have to be certain.
      billh
      • #4
        He is an aircraft mechanic so when he says they are pooched they are way beyond saving. ;) Yes they are 1 x 8TPI with the outboard being left hand.
        Victor Machinery have the dies for $31US so a little cheaper but still a lot if only needed once. Thanks so far.
        Pete
        • #5
          Unless you are real, real lucky the $31US is likely to be the cheapest solution assuming the threads will clean up sufficiently with a pass of the die. The threads just have to let the chuck, wheel, whatever thread on smoothly. The registration for alignment is against the shoulder, not the threads themselves.
          billh
          • #6
            I can’t help with General lathe parts, other than getting a donor lathe and they do come up, not often though.
            Yes the 160 has the 1”X8TPI both inboard and outboard with outboard being lefthand thread, the 260 has 1 ¼” X8 tpi inboard and 1 ⅛” X 8 tpi LH outboard
            He might not like to resurrect the outboard thread, but with a good thread file it can certainly made usable for say a hand wheel.
            You could get in touch with http://fordmachinery.com/index.php they do have a lot of used machinery.
ID:	1280979Click image for larger version
            QC Inspector likes this.
            Have fun and take care
            Leo Van Der Loo
            • #7
              Thanks for clarifying that Leo. I was pretty sure that the General that I worked on had 1 1/8 8 on the outboard side. It must have been the 260.
              Working...
