need alive center
  • Filter
  • Time
  • Show
Clear All
new posts
  • need alive center
    Recently acquired a wood lathe. It came with a static cup center. I want to get a live center but how do I get the correct size?
    The one have is a standard Morris taper I believe. The small end is about 9/16. The big end is about 11/16.
  • Thread Continues Below...
  • #2
    Re: need alive center
    Sounds like a MT2. Should be easy to find at Lee Valley or any other woodworking store near you.
    • #3
      Yes, very close to MT2 numbers and far away from MT1.   BTW, it's a Morse not Morris taper should you really care .
      Here is an inexpensive one from Busy Bee. I use the Oneway which comes with handy accessories, LV also has what they call a medium duty one as well.
      billh
      • #4
        I knew that. Same as the guy who invented the dot and dashes code. Just a sleepy brain drain.
        Links did not show.
        What is Oneway? Is that a brand?
        • #5
          yes Oneway Manufacturing makes everything for wood turning at their factory in stratford ontario
          not cheap stuff, one of the best!
          my 1940's lathe has all oneway accessories from chucks to well everything else
          their live center kit is a very useful quality unit with several accessory parts for different situations
          my shop is a beaver lodge
          steve, sarnia, ont
          1940's Craftmaster Lathe
          https://www.facebook.com/artistryinwoodca/
          • #6
            Thank you
            • #7
              I have this one, Lee Valley sells this one made by Oneway as others have mentioned. $129 Click image for larger version
              sigpic
              hobby woodworking since 1972
              • #8
                I have the same one as Bryan. Another handy feature of it is the rotating part is threaded 3/4-10TPI so you can get additional accessories or make your own to thread on. This can be handy at times since one of the most important things in woodturning right along with tool control is, "how do I hold this thing to turn it".
                The picture shows the large cone threaded onto the centre.
                billh
                Working...
