Acoustic guitar build (first attempt)
  • Filter
  • Time
  • Show
Clear All
new posts
  • #16
    Re: Acoustic guitar build (first attempt)
    A great thread
    Depending on what type of finish you're planning to use , I'd suggest that you make sure that the pale maple binding is to be isolated from the rosewood.
    Indian rosewood has a tendency to discolor ( sweep into ) the pale binding pores when finishing & this may cause problem the purple color on binding would be quite hard to remove , especially if the type of finish is french polishing.
    • Thread Continues Below...
    • #17
      Looking great! Those are some very nice looking jigs, and I really like the tool cabinet in the background. Can't wait to see the rest. Thanks for the thread.
      • #18
        Originally posted by Andre in Quebec View Post
        A great thread
        Oh I never knew that.. I may be past the point of no return at this point as you will see in the Future photos to come.
        • #19
          Here is the tail wedge. Cut by hand since it was short.. used a fine file to clean up the cut. Sanded down the wedge on the drum sander and once glued in place, flushed it with a card scraper.
          • #20
            • #21
              I soaked the binding in water, turned on the iron and bent them to fit the shape of the guitar. This was surprisingly easy and fun. Once dried they kept their shape very well.
              • #22
                • #23
                  Thanks for bringing us along for the ride. Building a guitar has always been something that has interested me, but the lack of any playing ability makes sure that being interested is all I do. I am enjoying the process though.
                  • #24
                    That is all that I have done so far. Next will be to glue the binding on the back and top and scrape everything perfectly flush.
                    The next big step will be to attach the neck to the body
                    stay tuned for more progress and hope everyone is enjoying the thread
                    Dave
                    • #25
                      • #26
                        Excited to see the neck build. I've wanted to build a guitar for a long time but keep overthinking the neck.
                        And yes I'm enjoying this thread as I'm sure many others are. You also take great pics. Thanks again.
                        • #27
                          Very nice work!
                          • #28
                            Nice job so far and thanks for sharing.
                            Jamie www.turneddesignsbyjamie.etsy.com
                            • #29
                              Looking real nice for a first build.
                              • “The greatest lesson in life is to know that even fools are right sometimes.”Winston Churchill
                              • #30
                                The neck came already shaped in the kit. It's definitely cheating doing it with a kit as a lot of the pieces are already done but for a first build, I thought it would be ok to cheat a little. This guitar is to prepare for the next build which will be from scratch.
                                Although the neck is already shaped, there is still a lot that can go wrong attaching it to the body. The guitar could easily turn in to firewood if the joint is not done correctly. There are a couple ways to make the neck joint and I'd love to make it a dovetail joint however I also want to end up with a useful guitar so I'd say I'll make it a bolt joint which is what a lot of well known high end brands do any way.
                                Working...
