Acoustic guitar build (first attempt)
  • Filter
  • Time
  • Show
Clear All
new posts
  • #61
    Re: Acoustic guitar build (first attempt)
    The bridge and everything else is mostly finished. I will likely round the edges a bit when it's time to do the finishing.
    All is left to do is the head plate which I am still waiting on the Abalone inlay.
    I will soon start finalizing the neck shape and neck angle/fit.
    Then I will be ready to final scrape/sand the body, spray the finish and final assembly and set up.
    Getting close to the end so I Bought a case yesterday
    • Thread Continues Below...
    • #62
      Looking really good and can't wait to see it with a finish.
      Jamie www.turneddesignsbyjamie.etsy.com
      • #63
        I finalized the shape of the neck and got the angle set and straight with the body. As daunting as it was, it wasn’t to much trouble.
        • #64
          I decide on a simple head plate inlay so it wasn’t bare. Inlayed a stylish letter G to represent my last name without actually putting my name on it. Scraped it flush and pretty happy with the result. Then I glued the head plate to the neck and flushed it up. The neck is now complete.
          • #65
            Drilled for the tuning machines. Pretty simple task.
            The tuners are just set in to make sure they fit.
            Next will I’ll be installing the dots in the fretboard and pressing in the frets
            • #66
              Rd1... have appreciated your work to date. What is the significance of the fretboard dots, not a musician so I see no particular use for them. Roy
              Are you solving the problem, or becoming part of it?
              • #67
                They are just for easy reference so you don't need to count the frets. The double dots mark the second octave on the fret board which is at the 12th fret. Different builders may mark them a bit different or leave some out but still at the same intervals, ei: 3rd, 5th, 7th, 9th, 12th, then it starts over.
                • #68
                  Thanks for the info, Roy
                  Working...
