Timber frame tools
  • Filter
  • Time
  • Show
Clear All
new posts
  • #16
    Re: Timber frame tools
    Originally posted by iamtooler View Post
    I had always heard that boxed heart was inferior timber?
    The best is "FOH" - Free Of Heart but that takes a massive tree for an 8x10 timber of any length. A well milled box heart timber sees the inevitible checking evenly distributed around the four sides. It also reduces the likelihood of grain runnout beyond specs for structural grading.
    Proud member of the Wadkin Blockhead Club.
    http://www.youtube.com/c/DovetailTimberworks
    • Thread Continues Below...
    • #17
      Originally posted by wbrent View Post
      I want to try my hand at timber framing this winter but don’t want to break the bank on tools. Right now I’m looking for two items. A couple of spiral drill bits. Large ones. 1 1/4” and 1 1/2” diameter Long enough to go through 6-8” beams. Also one or two matching mortise chisels to match. If there is such a thing. Anyone know where I can source such a thing? New or used. What else would you consider a must have for timber framing. And where would you source it.
      I'm not a timber framer but I have done a bit of it.
      I am using drill bits from a brace and bit - I cut the diamond shaped ends off and chuck them in a drill.
      Not as good as the wood owl bits but would work for practicing.
      I have a few old chisels from ebay/flea markets and 1 robert sorby from lee valley.
      I would recommend just buying the new one and not farting around cleaning old chisels.
      Unless you like cleaning old tools then go for it.
      https://www.leevalley.com/en-ca/shop...ortise-chisels
      https://www.leevalley.com/en-ca/shop...raming-chisels
      Nathan
      • #18
        What about the pins or pegs. I suppose I could just buy hardwood dowel. Or turn my own. Looks like some are whittled? Is the draw bore techniques always employed? Any recommendations for a good whittling knife. At least to taper the ends.
        • #19
          Dowel is usually undersized but can be ok if it's not really important. Draw boring is a good idea and you can just sharpen your pegs with your chisel.
          • #20
            Here is a rare tilting beam drill;https://www.lespac.com/en/beauharnoi...nt=BTN_Details
            245 dollars, too heavy to ship by mail. I could Potter if anybody wants it.
            • #21
              One more drill bit question. For those who are using drill bits to clear out mortises. If you have a 2” mortise to cut are you using a 2” drill bit or say a 1” drill bit and cutting twice the holes. I can’t find a 2” drill bit.
              • #22
                You certainly can go either way. I would be inclined to try something the same size as the mortise, perhaps a 16th smaller.
                Working...
