you can sand anything on a stroke sander. What grit im curious what you can do, likely finer on a stroke and thats why I asked and if hand clean up after Ive sanded Polyester with 600 grit before. What grit is used will show diff on diff woods and even diff boards same species depending on grain.
And for the vac cups always did plan on making a vac table but just sanded loose on the table. You dont need hold down to sand a cutting board other than put it on the table and get to work
