5" fittings
  • Filter
  • Time
  • Show
Clear All
new posts
  • 5" fittings
    Anyone know where to buy 5" fittings? Particularly dust hood types... blast gates seem easy enough to find.
  • Thread Continues Below...
  • #2
    Re: 5" fittings
    5" stuff can be difficult to find.
    Wellbeck has some http://www.welbecksawmill.com/Duct%20Work.htm
    As well as direct from oneida. https://www.oneida-air.com/inventory.asp?catid={7B0665DF-8BC3-420E-9047-327D1350E2A8}
    I had to make my own for my table saw for the 5" pipe. If you have the time to do it, it isn't difficult. If you don't have the time, you could always go to a local HVAC ducting company and I am sure they will make whatever you need for a price.
    You could also find a hood that fits your tool with a 4" connection and glue/screw a 5" flange over the 4" and then cut it out.
    • #3
      Re: 5" fittings
      Cool think I might just make my own fittings then using PVC plywood and silicone. Brettwood has 5" y's and a few places have 5" pvc and blast gates so think I'm in good shape so far.
      • #4
        Re: 5" fittings
        I used a bunch of hvac 5" fitting when I was putting together mine, worked pretty well.
        • #5
          Re: 5" fittings
          Yeah I'm good for that stuff what Im trying to find is a dust hood for my router table, table saw and jointer.
          • #6
            Re: 5" fittings
            A router table dust port is fairly straightforward, all you need is a way to connect a hose at the back of the fence.
            I was in a hurry to get to work so I made a rough mock up for mine. Basically a piece of wood with a hole in it to attach to my existing fence and a 5" pipe connector.
            From the front work side.
Name:	Router table dust port.jpg
            From the back, as I said, a quick and Dirty mock up
Name:	Router table back.jpg
            Not sure what you have for a jointer but mine has a built in chute. Piece of wood to cover the hole and some wood "fingers" to hold it on and allow for removal in case of a pile up !
Name:	Jointer dust port.jpg
            For the table saw I wanted above the blade collection too and the angles didn't work out so well with using Wye's so I built a manifold.
            This thread describes the build.
            Cheers, Don
            Don Kondra - Furniture Designer/Maker
            Product Photography
            My Acreage Bird Photographs
            • #7
              Re: 5" fittings
              Thanks Don, yeah thinking thats what I'll end up doing, just hoping for pre-made ones to save me some time. My router table one will be underneath though as I have an incra LS positioner. Thanks for the link, great to see other examples.
              • #8
                Re: 5" fittings
                Most hvac 5" stuff will work,but dont skimp on tee wyes, hvac is too abrupt for the most part,and if you have serious cfm,pvc can give you some static issues,be sure and run a ground strap if you go with pvc
                • #9
                  Re: 5" fittings
                  Thinking these for wyes... these too abrupt?
                  https://www.bardonsupplies.com/en/pr...c-a6810d7f65a8
                  • #10
                    Re: 5" fittings
                    I have a contact email for a guy @ Bardon in town. I'm trying to grt a list of what i will need, then sending it off to him.
                    He seemed confident they would have what I need, either in stock, or could be ordered.
                    [insert something witty here]
                    • #11
                      Re: 5" fittings
                      Yeah I'm trying to do the same... might grab a couple oneida fittings too but they're so expensive I want to keep them to a minimum. Maybe 2-3 tops.
                      • #12
                        Re: 5" fittings
                        That's basically what I used, bought them at Lowes...
Name:	15 - band saw hook up.jpg
                        Cheers, Don
                        Product Photography
                        • #13
                          Re: 5" fittings
                          Just found these, these look like what I want
                          https://www.homedepot.ca/en/home/p.5...000738232.html
                          • #14
                            Re: 5" fittings
                            if you need to crimp any duct work, I have the tool for doing so.
                            • #15
                              Re: 5" fittings
                              sweet! you the man!
                              Working...
