Oneida woes
  • Filter
  • Time
  • Show
Clear All
new posts
  • Oneida woes
    this is part question,part blabbering.
    had some sanding to do,as usual,put on my filter mask,opened up a blast gate above me,turned on the dc and started sanding. After a short time I realized I was in a cloud of dust,very little draw above. Fiddled with the other blast gates one by one ,no better anywhere else. So I pulled the bowl off the filter,very little dust. Had been cutting and routering mdf,thought I should clean the filter,it's been awhile.some dust,but not that bad. Right or wrong I started the dc without the filter,no noticeable difference.then I thought,the main duct must be obstructed,pulled it apart right at the cyclone,all looked good.started it up,not the greatest suction there! Thought I should check the impeller. Got a ratchet,climbed up and started to pop off the motor plate(gee,these bolts are easy to take out.) propped up the motor plate,all looks good. Tightened it back down,and decided to tape the seam between the top of the cyclone and the motor plate. Start it up,good thing the cats not near,wow what a difference. I guess it must have lost its seal at the motor plate.
    now,put it all back together,can't get a good seal at the top of the filter,never really have liked the way it's put together there,heads of carriage bolts in the seal,silly j hooks. Anyone got a better retrofit that is easier,like maybe a band type seal like at the drum?
  • Thread Continues Below...
  • #2
    Re: Oneida woes
    Al - Can you post a photo of the problem area? I am having a hard time visualizing the area.
    David
    • #3
      Re: Oneida woes
      David
      are you referring to the motor plate issue I solved,or the filter attachment I dislike?
      • #4
        Re: Oneida woes
        Al - I was referring to your question about a better retrofit in your last sentence.
        • #5
          Re: Oneida woes
ID:	1173469 Took this from the web,different model than mine,but same filter mount system.See the j hooks with the knobs? There are four of them,the j catches a channel in the end of the filter,you tighten up the knobs. One problem,no knuckle room,and you must be careful to tighten the four in a bit by bit sequence to get even pressure. Bigger issue,see the studs sticking up? They are carriage bolts (there are several,maybe 8?)that hold on the metal plate to the plenum, when you tighten the j bolts,the heads or the carriage bolts leave a imprint in the gasket of the filter. The gasket has a memory,and does not always return to the same place. Now I have several dimple patterns in the filter gasket and it will not seal
          • #6
            Re: Oneida woes
            For second, I thought you were complaining about the high-pressure side or low pressure side leaking around the fan/pump. Now I see your complaint. Using MDF many of the particles are as light as air. Most of them can travel through to the filter. If the filter does not have a good ceil on both sides, you will have leaks.
            Sir Isaac Newton.
            • #7
              Re: Oneida woes
              originally it seemed the lack of cfm was due to a leak on the suction side,where the motor plate bolts to the top of the cyclone.that was a easy fix,tighten up the bolts,add some tape,was trying to give a heads up to other cyclone owners,sudden loss of suction may be due to just this.im guessing the bolts simply backed off with the passage of time.
              the filter mount is a secondary annoyance that reared its ugly head in the coarse of trouble shooting the original issue
              • #8
                Re: Oneida woes
                Interesting, on my Oneida the filter is held on by a single threaded rod that goes up the center interior of the filter.
                A knob on the flat bar at the bottom of the filter is used to compress the filter gasket against the cyclone exhaust elbow.........Rod.
                • #9
                  Re: Oneida woes
                  The bolts on many parts of my cyclone needed regular tightening every few weeks for months as the gasket material slowly compressed. I agree the filter securing method is pretty hokey, but it does work, and if you're good about regularly blasting out the filter, you never really have to take it off.
                  Proud member of the Wadkin Blockhead Club.
                  http://www.youtube.com/c/DovetailTimberworks
                  • #10
                    Re: Oneida woes
                    Won't a lock washer help with that?
                    Noel
                    Noel
                    "Being so impressed with the beauty of nature, I never cease to be amazed at how the
                    'touch of the human hand' can transform it into another kind of beauty that is so uniquely human.
                    John Snow, Outdoorsman and Retired Teacher
                    • #11
                      Re: Oneida woes
                      Noel
                      The nuts weren't actually winding their way down-thread, they were staying put, but the material was slowly compressing leaving more space between the bolt head and nut, thus loosening them a bit.
                      • #12
                        Re: Oneida woes
                        I took the "silencer" out tonight,was able to seal it up with out much trouble,and no noticeable difference in noise level.Is there any issue running it this way I'm not thinking of?
                        • #13
                          Re: Oneida woes
                          After reading this I decided i should go check all the nuts and bolts on my Oneida that's just over a year old, sure enough most bolts were loose and needed an extra turn or 2.
                          Thanks for the warning Al
                          As for the silencer, there is nothing detrimental I can think of to removing it but I am by no means an expert.
                          • #14
                            Re: Oneida woes
                            al,
                            I removed my "silencer" years ago as I wanted to increase the filter area (the silencer blocks a good part of the filter, doesn't it?) and came to the same conclusion regarding noise reduction being nil to speak of. It's been off for a few years now with no degradation in anything.
                            All the best,
                            Marty
                            - Instagram: @apexwoodworks
                            - facebook: https://www.facebook.com/Apex-Woodwo...0243458908979/
                            Secretary of Kingston Wood Artisans Inc. https://kwoodartca.wordpress.com/
                            Master Mistake Fixer (because I've made them all... at least once)
                            Working...
