Will it work if...
  • Filter
  • Time
  • Show
Clear All
new posts
  • Will it work if...
    I've seen others have similar setups, but they were all using lager 6" connections - I have a Festool CT SYS extractor with 2 hoses (a 2.5" and the smaller one). I'm finishing my new router table where I was planning to have dust collection from both above and below the table. Will my CT using a 2.5" hose, plugged into a Y that goes out to the 2 ports on my table, have enough suction? (the table also would have 2.5" connectors and hoses probably) I'm going to add a dust collection port to both spots anyways, but I figure I should ask before I go to the trouble...
  • Thread Continues Below...
  • #2
    Re: Will it work if...
    Yes, but you should use a some form of intermediate separation. A cyclone - Clearvue mini, Oneida dust deputy to knock as much debris as possible to keep your extractor from clogging up.
    I have an original Clearvue mini sitting on a 20 litre wine juice pail attached to a Craftsman shop vac. It will keep up to my 16” Laguna spiral planer until the pail fills up. I have a 4” x 2 1/2” adapter.
    You need a robust waste bin as the vacuum generated will collapse even these wine juice pails.
    Don
    nnieman likes this.
    • #3
      I think it will work okay, but perhaps depending on your type of cut, you might just plug into one of the spots.
      For example if you're routing a dado down the middle of a board, the vacuum at the fence picks up minimal dust, you are better to focus on collection under the table.
      • #4
        Yes it should work but you will e
        will the extractor up really quickly.
        I used to use a large rigid shop vac with my router and it would get full.
        You can prob pick up a used shop vac off kijiji for $100 ish to dedicate to the router, if you use it a lot.
        Nathan
        Working...
