Air cleaner filters...
  • Filter
  • Time
  • Show
Clear All
new posts
  • Air cleaner filters...
    Can you clean them?
    I've got an older version of these:
    https://www.atlas-machinery.com/king...kaAkFBEALw_wcB
    Wondering how I should be cleaning the filters (washing?) or if I should just be getting new periodically?
    I've been vacuuming them, but I doubt that's really cleaning them well.
    -Jeff
    Sent from my SM-G950W using Tapatalk
  • Thread Continues Below...
  • #2
    Re: Air cleaner filters...
    If yogurt it cleaned put a cheap furnace filter in front and it's easy to change and replace.
    "Do it Right!"
    • #3
      Rusty's recommendation is a good one. I have shop-built cleaners made from old furnace fans and for each opening in the box I have starting from the outside:
      Cheap fibre-glass filter followed by a pleated filter (~$7) followed by a Filtrete expensive one on the inside.
      I spray the cheap outer filter with cooking oil to make it more sticky for dust. I've never had to change the Filtrete. The outer fibre-glass get changed more often than the pleated.
      Having slightly dirty filters is only an issue if you think the airflow is being compromised. IMO, a slightly dirty filter is better than a clean one since the trapped dust actually reduces the size of the holes. I'm sure this is likely a point of contention but as I said, IMO.
      Working...
