Solution for Clogs
  • Filter
  • Time
  • Show
Clear All
new posts
  • Solution for Clogs
    Hi everyone. I currently have a 1hp King portable dust collector. I work out of a 1.5 car garage so keeping my DC portable is important to me. The problem I have is, every time I use my jointer (only a 6 inch) I am constantly clearing clogs. Is a cyclone something that is going to prevent this from happening? if so, can someone recommend a very small or very portable solution for a guy who doesn't have much room to work with?
    Thanks
  • Thread Continues Below...
  • #2
    Re: Solution for Clogs
    Where does it clog up, in the ducting, at the inlet to the fan,exit from the jointer, same place every time ?
    Paul W.
    • #3
      I use a Lee Valley cyclone lid http://www.leevalley.com/en/wood/pag...82&cat=1,42401
      I find it works well
      Jerome
      Canada's South Coast
      Port Colborne On.
      Every loaf of bread is a tragic tale of grains that could've become whiskey.......but didn't....
      • #4
        If there is a screen/mesh piece in the dust collector inlet remove it but be aware of using the DC for floor clean-up. You do not want to suck up screws or metal pieces and have them hit the impeller.
        Check also on your jointer but I do not think there would be a screen on it.
        • #5
          yes generally it clogs at the DC intake right at the grate above the impeller, then due to loss of suction, the jointer gets clogged.
          I thought about clipping that grate on the DC, but thought maybe investing in a cyclone would be a better option.
          • #6
            Fwiw, removing the grate is part of my assembly process.
            • #7
              Me too. I also use a Thien top hat to keep nasties out of the impeller.
              works great.
              • #8
                I use one of these with my jointer and don't get any clogs. http://www.busybeetools.com/products...e-tornado.html
                • #9
                  I too removed the grate in front of the impeller. I also noticed that these plug up only occurred when planning softwood. The size of the shaving were really long compared to the shavings from hardwood. Anyway, I didn't have a plug up since then.
                  Chris
                  I only excel at fixing my my goof ups
                  Working...
