Removing protective oil on a metal lathe
  • Filter
  • Time
  • Show
Clear All
new posts
  • Removing protective oil on a metal lathe
    What do you guys use to remove the protective stuff that some Asian tools are sprayed with before shipping?
    Looks like some oil although some of it has dried and is pretty stubborn to get rid of.
    I've tried several de-greasers as well as lacquer-thinner but without much success.....so far none of the products I've tried seem to diluate the protective coating.
    Thanks
  • Thread Continues Below...
  • #2
    Re: Removing protective oil on a metal lathe
    It's been a while, but I used to use plain old varsol. And yes, I found some of it a bit difficult to remove.
    • #3
      You might try WD-40 or brake cleaner.
      What did you get?
      Craig
       [Is this like a game with the wacky characters being inserted automatically?]
      • #4
        Got a lathe from Busy Bee.
        By the time I've bought it it was on special at $3,000.000 iirc
        Most accessories and the lathe itself are coated with some kind of protective oil . I'm told on another forum that the protective stuff is called Rust Veto
        https://www.busybeetools.com/product...ith-stand.html
        • #5
          I do the same as John. Varsol and a lot of rags. Thick areas can be scraped with a PLASTIC scraper especially if you soften it some with the Varsol first. Rubber gloves and a respirator or work outside/lots of ventilation.
          Enjoy the new toy.
          Pete
          • #6
            My batch of varsol is probably too old.....tonight I'll give some gasoline a try.....who knows.
            • #7
              Get some new varsol, gasoline is too dangerous.
              schor likes this.
              • #8
                Gasoline won't make the cut either.......
                • #9
                  Andre....BusyBee must have some method to clean their floor models,  can’t see them leaving the demos covered with the protective coating.    Roy
                  Are you solving the problem, or becoming part of it?
                  • #10
                    Lantern kerosene from home hardware has disolved any grease and oil I've tried it on.
                    Andre in Quebec likes this.
                    • #11
                      Unless a container of Varsol or similar is left open it doesn't get "old". You can wash parts and let the stuff settle and pour off the clean portion and use it almost indefinitely. Gasoline shouldn't be used, not because it won't work but because it is much more dangerous. It just takes a lot of time and elbow grease. You could try other solvents but the nice thing about varsol is it leaves a little bit of an oily film that reduces rusting.
                      Pete
                      KenL likes this.
                      • #12
                        Yep, I've contacted Busy Bee Ottawa store where the lathe came from , but still awaiting an answer , the guy's name is Guy and he was very helpfull when I purchased the lathe , we'll see.
                        • #13
                          I am with Varsol. A light spray and 5 min later wipe off with a Cotton rage... and repeat.
                          KenL likes this.
                          Sir Isaac Newton.
                          • #14
                            I bought lots of tools from Guy; good fellow to know.
                            The anti-rust compound on your lathe should be pretty easy to take off with Varsol; it is all I used for my machinery.   You should not spray Varsol onto your metal lathe since it will get into places that you don't want it: bearings, wipers, bushings, etc.   Just wipe it on with a rag, let it soften the hardened spots and wipe it off with another rag.   I have taken plastic scrapers to some stubborn spots but haven't needed to do that very often.
                            Do check the gearbox lubricant in your lathe.   I flushed mine when it was brand new and replaced the goop that was in there with synthetic gear oil because what came in it wasn't doing the job, It was too thick to flow around the gears.
                            Good luck with your new lathe.
                            Ken
                            • #15
                              The coating may be Cosmoline although it is one of those trade names that gets used for any similar product. The removal is the same, Varsol which itself is a trade name referring to various brands of mineral spirits.
                              billh
                              Working...
