single phase variable speed
  • Filter
  • Time
  • Show
Clear All
new posts
  • single phase variable speed
    is there a simple explanation why there are no variable frequency drive systems for single phase motors?
    my shop is a beaver lodge
    steve, sarnia, ont
    1940's Craftmaster Lathe
    https://www.facebook.com/artistryinwoodca/
  • Thread Continues Below...
  • #2
    Re: single phase variable speed
    Probably because there is no way to disconnect the start winding at a low speed. And there is very poor torque at low speed.
    • #3
      ok so need another method of disabling the start circuit. low torque at low speeds is true of three phase too isnt it?
      steve, sarnia, ont
      • #4
        There are some expensive single phase variable speed motors mostly for fans but they will disappear now that vfds are available and cheap. 3 phase motors have natural torque as they have 3 sets of windings 120 degrees apart. Single phase has 2 sets in start mode then only one in run mode.
        Rob
        • #5
          3-phase provides a genuine rotating field to move the armature along which works well across a wide range of frequencies (which govern the speed). Single phase motors exhibit very poor characteristics at slower than rated speeds with torque far worse than a 3-phase motor at the same speed and the centrifugal start switch problem is another one. Also, single-phase motors are very likely to seriously overheat at slow speeds and are not designed for it.
          There is/was a company selling speed controls for single-phase induction motors but they didn't work with just any single-phase motor and to buy the motors was very costly.
          billh
          jgarrett forsberg likes this.
          • #6
            I posted this link once before. It looks like he is using an old Leland and simply controls speed and direction by changing the brush location https://www.youtube.com/watch?v=S5D9hL6LKM0
            • #7
              That is not a repulsion/induction motor, it is a repulsion only motor.
              • #8
                Fair enough, but it is still single phase variable speed control
                • #9
                  As is your drill! Induction motors are efficient and have no ''wearing parts'' except if there is a mechanical switch for the start windings. Note that you could use an electronic switch for that. Wound rotor motors are very expensive to build.
                  • #10
                    the motor in that video looks like a leland like the ones we all have on small machines.
                    but ours, i assume, are all repulse start,induction run
                    steve, sarnia, ont
                    • #11
                      That is exactly what I thought. I will defer to Rob, although I would like to know how he knows that it is not a repulsion induction, as the poster of the video claims.
                      Working...
