Bought a Tranny. Help !
  • Filter
  • Time
  • Show
Clear All
new posts
  • Bought a Tranny. Help !
    Got this at an Auction for $1 , it says 120 primary and 220 secondary, stupid question but can I actually run something up to 18 Amps on 220?
    Not that i need to but was curious about it. Click image for larger version  Name:	IMG_6509.jpg Views:	1 Size:	3.30 MB ID:	1233308
    • “The greatest lesson in life is to know that even fools are right sometimes.”Winston Churchill
  • Thread Continues Below...
  • #2
    Re: Bought a Tranny. Help !
    Basically yes, it should handle that continuously though it will get quite warm.
    Rob
    • #3
      Rob
      What kind of draw on the 120 would you need ?
      Not to run it at 18 amp but say 10 amps ?
      • #4
        exactly double the out put amps.
        • #5
          Thanks, Ill probably toss it.
          • #6
            Why on earth do that? lots of people want to run a 240v circuit even if only to use a vfd on a drill press. This allows it to be accomplished without hard wiring, no electrician or permit required.
            Rob
            • #7
              Well if someone wants it they can have it. It has odd outgoing powwr plugs.
              • #8
                There are 2 issues with that transformer
                1) it doesn't have an electrical approval so it can't be used.
                2) if it is a single winding 220 volt secondary, it's going to result in a system that's more than 150 volts to ground, that could also be a problem.
                Regards, Rod.
                • #9
                  Scrap it, though. Don't toss it.
                  Working...
