What is the best way to strip BX cable? I usually nip at it with side cutters but sometimes nip to deep and one end is always easier than the other. I was just wondering how others do it.
stripping BX
stripping BX
Jerome
Canada's South Coast
Port Colborne On.
CARPENTER noun. (car-pun-ter)
1) A person who solves problems you can't.
2) One who does precision guesswork based on unreliable data, provided by those of questionable knowledge. see also: wizard, magician.Tags: None
Re: stripping BX
I bend to break the armour, then use cutters to nip the aluminum. It can be challenging, but with practice, works well. There are dedicated strippers for AC90 armour, but I've never used any of them, so can't comment there. If I was starting over, I'd give them a shot, but I've been doing it this way for so many years and haven't felt the need to change, mainly because that's just one more bulky tool to have to carry.
Larger AC90, above #10, or teck cable, or liquid tight flex, I use Rod's method & cut at an angle with a fine tooth hack saw.
Whatever method you use, be sure to use an anti-short bushing. Inspectors seem to have special radar for missing anti-shorts, and for very good reason.ErikM likes this.
- 1 like
Re: stripping BX
Same here for the smaller size cables bend break and a little twist and cut with side cutters and hack saw for larger size cables. I have only worked with one other guy that actually bought the tool to cut BX but it seemed a little bulky and awkward to use but did give a clean cut.If you want me to make it i need this new tool first
Re: stripping BX
Originally posted by Rod Sheridan View PostI first learned to cut BX from my father, you never, ever, cut BX more than once with sidecutters
Of course for TECK or Coreflex you also use a hacksaw with a fine tooth blade.....Rod
Re: stripping BX
Originally posted by drzaius View Post
I do it all the time. Quick & mostly easy, but take practice.Work is the curse of the riding class.
Re: stripping BX
Oh, I agree, and I see it done all the time, just not when my dad was watching. He considered it a sign of poor work habits.....Rod.
Re: stripping BX
I'm curious as to why it is a sign of poor work habits. If done correctly, I see nothing wrong with it. What did he use?Work is the curse of the riding class.
Re: stripping BX
My father always used a hacksaw, he learned the trade in the 30’s and just had certain views on workmanship. Of course at that time small wiring was soldered, I still have his naphtha blow torch and soldering iron...Rod.
Re: stripping BX
Thanks, everyoneJerome
Port Colborne On.
Thread Continues Below...
