It has some electronics on it but would it run with out them if I wired it up direct to a switch? Its inside the fan still. I wanted to make it into an air filter. No idea the size think it may be a 1/2 or 1/3 hp.
Electric motor from a furnace.
Re: Electric motor from a furnace.
Originally posted by drzaius View PostSome high efficiency furnaces have DC fan motors that are powered by a variable speed controller.my shop is a beaver lodge
steve, sarnia, ont
1940's Craftmaster Lathe
https://www.facebook.com/artistryinwoodca/
It should have 4 wires and a ground White is natural, Red is low speed, Blue is medium, and Black is high speed. if you know how fast you want it you can just use a common switch or you can use a 3 pole switch to switch speeds.Jerome
Canada's South Coast
Port Colborne On.
CARPENTER noun. (car-pun-ter)
1) A person who solves problems you can't.
2) One who does precision guesswork based on unreliable data, provided by those of questionable knowledge. see also: wizard, magician.
Ok So on the motor there was the standard sticker giving the phase hp and amperage it is 120 volt so that is good. 1/3 hp 5 amp. But there are these mounted on the outside of the cage as well as a circuit board. So I am wondering if I can by pass them. Ok Guess I have to resize the stupid pics. I hate that. Took them with my phone not like they are hi def or anything. My lord.
One of the items is a transformer says its 40 va 50/60 Hz 24 volts must be for the control system off the furnace.
The other thing looks like a capacitor. 12.5 uf 370 vac + or - 6% Protected P021
I don't know what the rest of the numbers are at all.
The computer board is about 4" X 6" No idea if that is actually for the motor or not. There is a total of 7 wires coming out of the motor plus a green ground.
Thread Continues Below...
