Results 1 to 13 of 13
Thread: Grinder speed control
  1. #1
    Join Date
    Apr 2006
    Location
    White Rock BC
    Posts
    102
    Real Name
    Ken Kimberley
    Default Grinder speed control
    I have a bench grinder that runs at 3400 RPM. I would like to be able to reduce the speed on it to about 1700 RPM. Is it possible to use a rheostat (dimmer switch) to reduce the speed or will that just cause the motor to overheat? Any suggestions?
    Ken K in White Rock
  2. Thread Continues Below...
  3. #2
    Default Re: Grinder speed control
    You can't slow it down. Maybe a better grinding wheel would do the trick. What are you trying to sharpen?
    hobby woodworking since 1972
  4. #3
    Join Date
    Dec 2007
    Location
    Orangeville, Ontario, Canada
    Posts
    2,435
    Quote Originally Posted by Ken Kimberley View Post
    Interestingly enough, I was just about to try this, myself. I have an old purpose-made rheostat for slowing motors. It's not just a dimmer switch, it's a 3-pound box with some 'stuff' in it. For a while there you could buy boxes made for adding a variable-speed ability to the first generations of hand-held routers. These might work as well. I'm going to grab my rheostat from my old shop this weekend and try it out. I'll let you know how it goes. I'm not sure how well it will work because most of the variable-speed stuff out there is based on a 'universal' motor which is almost a re-badged DC motor... it's got brushes and whatnot. Lots of hand-tools have universal motors, but standard bench grinders don't. So it might not work, and it might burn out the motor by running it so slowly that the starting coil never de-energizes... but as I said I'll let you know.
    Mike in Orangeville, ON
    http://ifonlyyouwood.blogspot.com/
    SPCHT
  5. #4
    What about a foot actuated switch? Turn the grinder on and off to maintain the speed you want. Probably no worse then a rheostat?
    Probably a whole host of things wrong with the idea that I can't think of. (read: disclaimer )
    Cheers,
    Erron.
    The grain has more direction then me sometimes.
  6. #5
    Join Date
    Sep 2007
    Location
    Sault Ste Marie
    Posts
    574
    Real Name
    Todd Robert
    A dimmer switch is NOT the item to use. What you need is a speed control like what is used for a router. This is one that is sold from Rockler but i am sure there are lots of different ones around.
    If you want me to make it i need this new tool first
  7. #6
    Join Date
    Dec 2007
    Location
    Posts
    2,435
    Quote Originally Posted by Todd View Post
    I see they still make those things. Cool. If you look at the label on the front of it in that picture you posted you'll see that it specifies that it's for universal motors. Bench grinders don't have universal motors, so I'm not positive yet that it's going to work, but I'll try it out. My grinder is cheap enough that I'm not overly worried about burning it out.
    SPCHT
  8. Thread Continues Below...
  9. #7
    Join Date
    Sep 2007
    Location
    Sault Ste Marie
    Posts
    574
    Real Name
    Todd Robert
    The other thing to do is to check with an electrical wholesaler like Westburne, Nedco, Guillevin Int. or some place like that and see what they have available to suit your needs.
  10. #8
    Join Date
    Feb 2006
    Location
    Mount Hope Ont.
    Posts
    8,011
    Real Name
    J.P.
    I think it can be done but you need a speed controller designed specifically for induction motors. It would likely be cheaper to buy a new grinder. Also, it's not good for the motor and could over heat it.
    There are speed controllers for ceiling fans which have induction motors but it's a different type of wiring then a grinder motor and it's built for that propose.
    Is it viable to put a smaller wheel on the grinder to bring the rim speed down to equal that of a slower grinder? On an 8" grinder that would mean a 4" wheel but 6" would at least get you closer.
    At 3450 RPM, The rim speed of an 8" wheel would be around 7200FPM. The rim speed of a 6" wheel on the same grinder would be around 5400 FPM.
    The rim speed of an 8" wheel at 1725 RPM would be around 3600 FPM.
    FWIW
    J.P. Rap Mount Hope Ont.
    Carpe Ductum (Seize The Tape)
  11. #9
    Instead of destroying a good grinder, why not get something that grinds easier. Use a belt sander if you have one. My favourite sharpening machine before I got a worksharp is a 1" wide belt sander. I only use the 8" grinder for very heavy sharpening , like lawn mower blades. Using a reheosat on your grinder won't work, wrong type of motor, and once you let the smoke out , it's done
  12. #10
    Join Date
    Apr 2006
    Location
    White Rock BC
    Posts
    102
    Real Name
    Ken Kimberley
    Thanks for all the input. Most of it is what I expected - don't do it! I'm finding it far too fast for sharpening chisels for turning. It's an 8" and I'm using a white Norton stone (I can't remember what the exact grit is). I'll probably look at the Delta variable speed or the work sharp.
    Thanks again.
    Ken
    Ken K in White Rock
  13. #11
    I would search the turning forum or ask again on the turning section about sharpening lathe chisels. I think you would be disappointed in trying to use a Worksharp for the different types of lathe chisels. I find mine is more suited to bench chisels and plane irons. Lathe chisels seem to need touch up every 10 minutes. I still use my 1" belt sander , though not ideal for lathe chisels it does what I need and doesn't burn. I don't turn enough to have have a proper set-up. J.P. would be the one to ask. He has a tutorial in tutorial section, but seems the pictures are missing. I think you have the right tool, just need to refine the method.
  14. Thread Continues Below...
  15. #12
    Ken, I use both a 3450 RPM 6" grinder and a 1750 RPM 8" grinder both of which are fitted with white 120x Norton wheels for sharpening my HS Steel turning tools. Neither is a problem for overheating unless I get too aggressive. I use the Wolverine jig for my gouges with a very light touch and bluing the edge is never a problem. I do make a point of keeping a can of water close by to cool the tool regularly if I'm grinding a new profile or modifying an existing one.
    Steve
    Richmond, BC
    Anything worth doing is worth overdoing.
  16. #13
    Join Date
    Feb 2006
    Location
    Mount Hope Ont.
    Posts
    8,011
    Real Name
    J.P.
    Ken
    An 8" at 3450 RPM is way to fast for turning tools. I use a 6" 3450 RPM grinder and it works very well but it took a considerable amount of practice to get the a point where I wasn't burning the chisels. That said I use gray stones and they aren't nearly as friable as the white stones.
    Try just putting a 6" wheel on you 8" grinder. Lowering the rim speed a bit might be just what you need.
    Quote Originally Posted by Bryan @ Woodstock View Post
    Yes. I've been meaning to fix that for some time now. The hosting site I was using at the time closed down and I have to find the pictures in this pile of discs.
    Edit...I did a search for past threads as I knew there were a bunch of them.
    Have a look here. Scroll down a bit to "grinders and wolverine". You'll find that one full of info as well as a few other interesting threads.
Similar Threads
  1. Router Speed Control Question
    By Donna H in forum Shop Related Discussions
    Last Post: 01-21-2010, 06:21 PM
  2. Replies: 13
    Last Post: 01-28-2008, 09:40 PM
  3. Router Speed Control
    By matt in forum Shop Related Discussions
    Last Post: 04-25-2005, 01:29 PM
  4. Router Speed Control
    By Walter in forum Shop Related Discussions
    Last Post: 04-21-2005, 03:41 PM
  5. Router Speed Control
    By Pam in forum Shop Related Discussions
    Last Post: 08-20-2003, 07:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
