Results 1 to 16 of 16
Thread: Drilling Perpendicular Holes without a Drill Press
  1. #1
    Join Date
    Sep 2007
    Location
    Conception Bay South
    Posts
    358
    Real Name
    Ed
    Default Drilling Perpendicular Holes without a Drill Press
    Hey everyone,
    I tried to drill the holes for the bridge posts for the Les Paul copy guitar I'm building only to discover that my drill press isn't deep enough. Any suggestions on how to drill this with my handheld drill? I was thinking about attaching 3 speed squares around the holes and putting the drill in between all of them. At least then I'll have a reference for keeping the drill upright. Think this will work?
    Alternatively, if I decide to buy a router bit to do this with my plunge router instead, what type of bit would be best for boring holes? (assuming I can get a 7/16" bit). One of those spiral upcut type bits?
    Thx
    Kids, you tried your best and you failed miserably. The lesson is, never try
  2. Thread Continues Below...
  3. #2
    Join Date
    Feb 2006
    Location
    Ottawa
    Posts
    3,307
    Default Re: Drilling Perpendicular Holes without a Drill Press
    A router will work fine. Lee Valley has 7/16" bits, for some reason they are quite a bit more expensive than the 1/2". I'm not quite sure what you mean by using 3 squares ??? The router will need a flat stable surface to reference off of.
    Paul
  4. #3
    Join Date
    Mar 2007
    Location
    sarnia ont
    Posts
    11,097
    Real Name
    Steve Morris
    a plunge router would the best way, any style would work but an up spiral would be the best
    just clamp the router in place somehow and plunge away
    i cut the bench dog holes in my bench that way
    my shop is a beaver lodge
    steve, sarnia, ont
    1915 or so crescent
  5. #4
    Join Date
    Feb 2006
    Location
    brantford Ontario, Canada
    Posts
    95
    Take a thick block of wood and drill a hole in it with the drill press then when clamped in place it will guide your hand held drill bit into your other piece. HTH
    kEITH
  6. #5
    Join Date
    Mar 2006
    Location
    Sudbury
    Posts
    1,928
    What Keith from Brantford (brother of Wayne from Brantford?) says. Done this many, many times - never had a problem.
    Max
    "Time is a great teacher, but unfortunately it kills all its pupils."
  7. #6
    Join Date
    Feb 2006
    Location
    Northern Kentucky, USA
    Posts
    2,517
    Quote Originally Posted by Keith in Brantford View Post
    kEITH
    I was going to say that..... Best idea, I do it often with great success.
    Attached Images Attached Images
    Bill "Hickory" Simpson
  8. Thread Continues Below...
  9. #7
    Join Date
    Mar 2007
    Location
    Seguin, Ont.
    Posts
    5,311
    Real Name
    Ryan
    kEITH
    I was also going to say this, but with a twist: if you have a dowel jig, depending on the design of the one you have, many of them can easily be clamped to a flat surface and used to guide a perpendicular hole.
    Alternately, B&D offers an accessory for a standard workmate: a drill press holder thing. It's basically a stand with a sliding holder on it. You put the stand in the workmate vice, clamp it tight making sure it's true and vertical, then a standard drill will clamp into the holder and slide up and down on the stand, thus allowing you to drill perpendicular holes of any depth on the workmate.
  10. #8
    Just out of curiosity...
    You said your drill press wasn't 'deep enough'. did you mean throat depth? Or you just couldn't drill a deep enough hole? I don't understand where you are tring to drill holes (I have read your other posts, very cool btw) but (and I assume you have) have you tried it from different angles? (assuming the former?)
    I'd love to see more pics of your progress. Good luck with the drilling!
    Cheers
    Erron.
    The grain has more direction then me sometimes.
  11. #9
    Join Date
    Sep 2007
    Location
    Posts
    358
    Real Name
    Ed
    Throat depth is the issue. Due to the shape of the body, I cannot position it anyway to get the holes for the bridge posts (see photo) in under my drill bit.
    Never thought of the block of wood idea. How thick of a block to be accurate? The drill bit is about 3.5" in length and the depth of the hole needs to be about .5" - So would a 3" thick block be good?
    As for using the squares - I got the idea from a similar setup in a woodworking magazine. Basically position 2 or 3 speed squares around the hole to provide vertical references when holding the drill upright. But I'm liking the block of wood idea more.
    THx guys.
  12. #10
    Join Date
    Feb 2006
    Location
    Posts
    2,517
    That should be a snap with a block of wood, 3" is extreem, 3/4" should do fine or 1 1/2" max. anything thicker is a waste and creates friction and problems with chip removal.
    I would get a piece of hardwood long enough to reach across. Mark the piece with the location of the two hole , drill, etc. then locate the holes over the marks on the project and clamp down. Procede to drill through, unless you force it sideways, the drill should follow the predrilled holes and reproduce their orientation.
    Works the same principle as the Kreg Jig (except 90 degrees in lieu of the low angle)
  13. #11
    Join Date
    Sep 2007
    Location
    Posts
    358
    Real Name
    Ed
    Thx guys. I've got some 1" pine that I'll use. Now what's the chances the missus is gonna let me in the shop on Christmas Eve night to try this?
  14. Thread Continues Below...
  15. #12
    Join Date
    Feb 2006
    Location
    GTA, Ontario.
    Posts
    3,101
    Quote Originally Posted by ewjsmith View Post
    Pine would work but a harder species like oak is better because it is acting like a bearing for the drill bit to keep it aligned vertically.
  16. #13
    Join Date
    Mar 2007
    Location
    Seguin, Ont.
    Posts
    5,311
    Real Name
    Ryan
    Quote Originally Posted by Rick Thom View Post
    that's why I recommended a dowel jig, if he has one that will lay flat: its bushings would likely be much better even than oak. I use an old wolfcraft for this all the time.
  17. #14
    Join Date
    Dec 2008
    Location
    Gulf coast of Southwest Florida
    Posts
    101
    This is my first post, so be kind. Also, pardon my rust.
    Years ago I bought an accessory called a PortAlign. Basically, you remove the chuck from the drill, then attach the drill and the chuck to the "wing" on the device.
    It then allows you to drill perpendicular holes ANYWHERE, and there's an adjustable stop to control the depth of the hole. The top of the baseplate also has two V shaped tabs that allow drilling in the center of round stock.
    By extending the guide rods, you can consistently drill holes on an angle or perfectly center holes for edge drilling.
  18. #15
    Join Date
    Nov 2008
    Location
    Pangman SK
    Posts
    98
    Real Name
    Kenny
    Plunge router would be my first choice with a spiral cut bit...fast and accurate!
  19. #16
    Join Date
    Sep 2007
    Location
    Posts
    358
    Real Name
    Ed
    Hey Ray - that one cool looking "drill press". Busybee carries something similar now:
    http://busybeetools.ca/cgi-bin/picture10?NTITEM=B2099
Similar Threads
  1. Drill press with a long reach
    By Robin in Niagara in forum Power Tools
    Last Post: 07-23-2007, 09:53 AM
  2. Ridgid Drill Press - In the shop but..........
    By Randy in Calgary in forum Power Tools
    Last Post: 05-02-2006, 11:46 AM
  3. Drill Press Table Fence, How High?
    By Gord In Brantford in forum Shop Related Discussions
    Last Post: 04-01-2006, 09:00 AM
  4. Pocket hole jig-homemade
    By Don from Brantford in forum Woodworking
    Last Post: 12-20-2001, 07:36 PM
  5. Powermaxx Drill press
    By ken wulff in forum Power Tools
    Last Post: 09-13-2001, 09:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
