Results 1 to 5 of 5
Thread: No ground wire on old 1/4 hp motor?
  1. #1
    Default No ground wire on old 1/4 hp motor?
    Hi guys,
    I just picked up an old 1/4 horse motor for my lathe. The crazy thing has a toggle switch on it! The plug on it currently is older then me. 2 prongs, no ground. No green wire evident beneath the switch either. I'm obviously going to update the wire and bypass to the toggle switch to the power switch for my lathe.
    Should I just loop the ground wire from the lathe switch around one of the screws for the motor cover plate? Should I just not bother to connect it at all (on either end)?
    The current wiring set up works (and has worked I assume for 40 years?). I just want to update it without potentially shocking myself down the road in case something goes amiss.
    Thanks for any tips,
    Cheers
    Erron.
    The grain has more direction then me sometimes.
  2. Thread Continues Below...
  3. #2
    Join Date
    Dec 2007
    Location
    Orangeville, Ontario, Canada
    Posts
    2,435
    Default Re: No ground wire on old 1/4 hp motor?
    Run the ground to the motor's chassis. While looping it under one of the screws that hold the it together would work, a crimped lug would be nice.
    Mike in Orangeville, ON
    http://ifonlyyouwood.blogspot.com/
    SPCHT
  4. #3
    Join Date
    Feb 2006
    Location
    Halifax, Nova Scotia, Canada
    Posts
    738
    Quote Originally Posted by Mike Graham View Post
    "would be better"
  5. #4
    Thanks Mike. I've got lugs and a crimper and will use them. If you hadn't made that suggestion I probably would have forgotten all about it.
    Cheers,
    Erron.
  6. #5
    Join Date
    Feb 2006
    Location
    Burlington
    Posts
    1,740
    Default On the end of the motor
    Is there not a ground screw? Alot of older motors had a ground screw on the end of the motor. Personally unless your turning some pretty small stuff a 1/4hp is not much power.
Similar Threads
  1. I need help wiring my bandsaw for 240V.
    By JPlourde in forum Shop Electrical
    Last Post: 11-19-2007, 09:08 AM
  2. I think my table saw just died!!
    By Charles in Lorette in forum Power Tools
    Last Post: 02-22-2007, 11:05 AM
  3. Anyone know how to wire a motor?
    By JohnSo in forum Shop Electrical
    Last Post: 12-14-2006, 10:53 AM
  4. ATTENTION: Cyclone builders in need of a motor>>>
    By Steve In Kemptville in forum Dust Collection
    Last Post: 07-23-2003, 07:53 AM
  5. 230 volt motor wiring ....
    By Woody in forum Shop Electrical
    Last Post: 07-26-2001, 07:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
