Results 1 to 11 of 11
Thread: Mount tool box to trailer
  1. #1
    Join Date
    Feb 2006
    Location
    Keswick, Ont
    Posts
    1,091
    Default Mount tool box to trailer
    I was able to buy a tool box from Princess Auto today prior to their sale on Tuesday that I would like to mount it on my trailer tongue. It is on page 27 of their flyer starting on May 25th. How do you mount tool boxes to your trailer tongue? I will probably put a piece of ply down first for support.
  2. Thread Continues Below...
  3. #2
    Join Date
    Mar 2006
    Location
    gloucester on
    Posts
    2,061
    Default Re: Mount tool box to trailer
    I would use a piece of ply with u-bolts that go under the tongue ,up through the ply & through the box .
  4. #3
    Join Date
    Feb 2006
    Location
    Halifax, Nova Scotia, Canada
    Posts
    738
    Quote Originally Posted by akabek View Post
    What type of trailer is it??? Travel trailer, Tent trailer,utility trailer or other????
    Anything on tongue now?? Is weight a consideration??
  5. #4
    Join Date
    Nov 2008
    Location
    South Shore Nova Scotia
    Posts
    2,533
    A couple of pieces of angle iron welded to the tongue could be one way.
    Question, will the box interfere with turning sharply?
    Egon
    from
    The South Shore, Nova Scotia
  6. #5
    Join Date
    Feb 2006
    Location
    Keswick, Ont
    Posts
    1,091
    It is a 5x10 utility trailer. Here is what it looks like.
    http://hitchmantrailers.ca/catalog/images/BT583R.jpg
  7. #6
    Join Date
    Feb 2006
    Location
    Muir, near Woodstock,Ont.
    Posts
    5,508
    I would check out how it will interfere with the turning radius especially when you are backing up and the thing jack knifes, believe me , it is very easy to do. I would build a bracket so it sits above the box on the front.
    Brian
  8. Thread Continues Below...
  9. #7
    Join Date
    Nov 2008
    Location
    Posts
    2,533
    From the looks of the trailer It's very likely to do some damage to the tow vehicle on tight turns.
    Just set the box on the tongue to check it out.
    An alternative may be to mount your toolbox across the top of the box at the front or on top along the side of the trailer box.
    Note: I'm assuming you have purchased a toolbox that is the full width of a P/U truck box.
    Egon
    from
  10. #8
    Join Date
    Mar 2009
    Location
    Alberta
    Posts
    10,441
    If the toolbox does not extend past the triangle of the tongue it shouldn't be a problem should it?
  11. #9
    Join Date
    May 2008
    Location
    Campbellton, NB
    Posts
    488
    Quote Originally Posted by Rusty View Post
    No, just watch your tongue weight.
  12. #10
    Join Date
    Feb 2006
    Location
    Posts
    5,508
    I am assuming, dangerous thing to do,that it is a tool box that sits across the front of a p/u box and they are usually in the 4 1/2 to 5 ft wide. the one i have is 58 in wide and 22 in deep which would stick into the bumper on a sharp turn. His trailer looks about 5 ft wide
    Brian
  13. #11
    Join Date
    Oct 2009
    Location
    Posts
    366
    Quote Originally Posted by Brian @ Muir View Post
    Brian
    To see how much room you have hook the trailer to your vehicle and drive one full circle at your tightest radius the car will do. Put car in park, hop out and looking at the tongue you'll see the maximum room you have to work with GOING FORWARD. In reverse you'll be able to jackknife the thing and rough up your bumper regardless of any toolbox additions.
    Note the room you have will vary vehicle to vehicle so if this trailer is towed behind multiple vehicles, repeat for each one.
Similar Threads
  1. "Stronghold" Box
    By flairwoodworks in forum Woodworking
    Last Post: 01-22-2010, 01:07 AM
  2. Children's tool box
    By Brendan in forum Woodworking
    Last Post: 12-06-2009, 09:05 PM
  3. Carpenters tool box
    By wilson in forum Woodworking
    Last Post: 11-27-2008, 11:25 PM
  4. Tool Box From Feburary/March 2007 issue
    By Jordan Friedrich in forum Woodworking
    Last Post: 07-30-2007, 12:23 PM
  5. home made portable tool box help
    By RodinRegina in forum Woodworking
    Last Post: 02-26-2007, 10:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
