Results 1 to 2 of 2
Thread: Pure tung oil, drying time and other questions
  1. #1
    Join Date
    Feb 2006
    Castlegar, B.C.
    Default Pure tung oil, drying time and other questions
    I'm trying pure tung oil for the first time just because I've never used it before. Project is a combinaton of maple and mahogany. How long does this stuff take to dry/cure? I applied as per directions and have waited 48 plus hours. The finish does not feel gummy, but when I touch it, I can see oil on my finger. This is my 3rd application. The first 2 I just waited 24 hours, and wiped it down before I applied more. The mahogany seems to be greasier. Also, for storage purposes, I understand I can just add water to the can and keep it topped up. Oil will stay on top?
  2. Thread Continues Below...
  3. #2
    Join Date
    Nov 2007
    Fort Saskatchewan, AB
    Default Re: Pure tung oil, drying time and other questions
    Temp and humidity can affect the curing time. If you haven't applied any more oil since you first posted but continued to rub the piece down with clean rags everyday even 2-4 times a day, you should notice a difference. If not, soak a rag in thinner and rub it in. You will remove some of the oil but the thinner will dilute the oil a bit and help it penetrate a little deeper. As the thinner evaporates, the oil resins should start to react with oxygen to cure.
    Cure time are approximate. There first couple can take much longer so best not to rush.
Similar Threads
  1. Time span for drying my Fresh cut wood
    By joshsmith1979 in forum Woodworking
    Last Post: 12-27-2014, 08:28 PM
  2. Questions about Tung Oil thinner & tinting?
    By kona in forum Finishing and Refinishing
    Last Post: 04-04-2010, 11:49 AM
  3. Pure Gloat
    By John@Hamilton in forum Turning
    Last Post: 03-29-2009, 09:40 PM
  4. First time here - Specific table saw purchase questions
    By Doug Rempel in forum Power Tools
    Last Post: 01-21-2009, 11:30 AM
  5. First time router cut questions
    By Shamus in forum Power Tools
    Last Post: 10-04-2007, 11:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
