Results 1 to 10 of 10
Thread: Salad Bowl Finish - Polymerized Tung Oil
  1. #1
    Join Date
    Sep 2012
    Location
    Belleville
    Posts
    4
    Default Salad Bowl Finish - Polymerized Tung Oil
    Is polymerized tung oil (Lee Valley) food safe? I've heard that a good finish for salad bowls is pure tung oil, so I wondered if I could use polymerized tung oil instead. Does it dry faster than pure tung oil? Thanks in advance for any help.
  2. Thread Continues Below...
  3. #2
    Join Date
    May 2007
    Location
    Atikokan, Rainy River District, Ontario.
    Posts
    6,998
    Real Name
    just what you thought :^')
    Default Re: Salad Bowl Finish - Polymerized Tung Oil
    Quote Originally Posted by henry1 View Post
    Hi Henry , I have used both pure and polymerized Tung oil, the pure does dry slower, but not very slow, like Linseed oil or Walnut oil, as these are also used sometimes, but they really "take forever" to polymerize.
    Pure Tung will take from overnight to a full day to polymerize, depending temp and humidity levels (best temp is about 20C and lower than 60% humidity)
    Polymerized Tung oil will polymerize faster because of the driers added, and is essentially food safe when fully polymerized.
    I will add some info here, some of which I have and have taken parts from it as the whole piece is too long to add here.
    My personal preference is the Polymerized Tung oil, as it gets harder and gives a higher luster/shine, though a salad bowl does not really need a finish like that, but of course I don't beforehand know what uses a bowl gets, so that's why I do add a finish like that, HTH
    Have fun and take care
    Leo Van Der Loo
  4. #3
    Join Date
    Feb 2006
    Location
    IcandrivetoOttawa
    Posts
    4,464
    Real Name
    Bill
    My only addition is to be sure to read the label on the container. There are lots of things that get called tung oil and the like that may have very little in it and are mostly linseed oil.
    billh
  5. #4
    If you do a search for food safe wood finishes you will find several research papers that state any finish is food safe once the solvents have totally evaporated.
    This has been mentioned several times on the AAW web site and on other turning forums. HTH.
  6. #5
    Join Date
    Jun 2012
    Location
    Timmins, Ontario, Canada
    Posts
    2,446
    Real Name
    Andrew J. Coholic
    Raw linseed, or raw tung are food safe (as are walnut oil, medicinal grade mineral oil and others).
    Anything that is "polymerized" ( poly tung oil, danish oil, boiled linseed, etc) has metalic salts and solvents added to aid in the drying, and are generally NOT recommended for food contact items.
    For my food contact wooden turnings, cutting boards, etc I use Boos block oil. It is inexpensive, and convenient, and 100% safe for anything you are going to put food in. There is also a more "plastic" looking finsih which is food safe, sold by Behlan (sp?) I used to buy through Richelieu Hardware, but I prefer the oil myself.
    AJC
    Andrew J. Coholic
    Joe Coholic Custom Furniture Ltd.
    www.joecoholiccustomfurniture.com
  7. #6
    Here's a few of many places for some reading. Note that the general consensus is that even something labelled food safe will still contain driers and solvents because there's been no link to any cases of health damage to humans when the "toxic" additives are completely cured.
    I use my own mix of varnish, oil and turpentine which is allowed to cure completely for about 30 days and then buffed with carnuba wax.
    Usually the source of information about the safety of finishes comes from the manufacturer of the finish and the label "food Safe" is purely advertising sales promotion because the FDA and others have not banned sthe use of the driers and chemical salts.
    http://voices.yahoo.com/food-safe-fi...t-6309070.html
    http://www.woodturnerruss.com/FSOriginal3a.html
    http://gvwg.ca/docs/Articles/Mark%20...%20safe037.pdf
  8. Thread Continues Below...
  9. #7
    For food contact items I like General Finishes Salad Bowl Finish. Very easy to apply and as the name says good for that use.
  10. #8
    Join Date
    Feb 2006
    Location
    IcandrivetoOttawa
    Posts
    4,464
    Real Name
    Bill
    Quote Originally Posted by venom813 View Post
    Here is the MSDS sheet for it:
    http://www.generalfinishes.com/sites...ear-2-4-09.pdf
    As you can see with the ingredients and related hazards it is not to be treated like distilled water regardless of its name.
    To be clear, I'm not an alarmist and am firmly in the camp that says pretty well any finish on the market is food-safe once it is cured and that is cured, not just dry.
    billh
  11. #9
    Join Date
    Sep 2012
    Location
    Belleville
    Posts
    4
    Thank you for the informative feedback. I appreciate all the links to further reading.
  12. #10
    Join Date
    Dec 2007
    Location
    Elora, Ontario
    Posts
    856
    Real Name
    Dave Bell
    I could not find the article, but I will keep looking for it. It basically states like mentioned above, that @ 30 days is all that is required for the oil to cure before it can safely be used as a food safe finish.
    Dave
Similar Threads
  1. Polymerized Tung Oil
    By Steven@Barrie in forum Finishing and Refinishing
    Last Post: 05-07-2012, 09:38 PM
  2. Salad Bowl Finish in Canada
    By DonOtt in forum Finishing and Refinishing
    Last Post: 01-18-2011, 06:39 PM
  3. Polymerized tung oil
    By Mike Tyson in forum Finishing and Refinishing
    Last Post: 02-21-2010, 03:16 PM
  4. Salad Bowl Finish
    By Glenn at Raven in forum Finishing and Refinishing
    Last Post: 12-03-2009, 12:10 PM
  5. Salad Bowl finish
    By John from Markham in forum Finishing and Refinishing
    Last Post: 12-20-2004, 07:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
