Results 1 to 6 of 6
Thread: Connecting bathtub drain to main vent stack.
  1. #1
    Join Date
    Apr 2010
    Location
    Toronto
    Posts
    138
    Default Connecting bathtub drain to main vent stack.
    I'm getting some conflicting advice about the best way to join a tub drain to the main stack.
    The book Remodel Plumbing (Rex Cauldwell) warns against using anything but a sanitary T-fitting when joining a sink to a vertical drain/vent because having a fitting with too much sweep will cause a siphoning effect. I'm wondering if the same principle applies when joining a 1-1/2" tub drain to a 4" vent stack (the P-trap is about 5 feet from the stack)
    I'm joining a bathtub drain to a main stack and can't make the connection anywhere near level to the P-trap. I need a drop of about 10". Going by the book, I'm thinking that this configuration would work:
    ...but I've also been told that this setup with a Y and short 45 would work perfectly fine:
    Any informed opinions?
  2. Thread Continues Below...
  3. #2
    Join Date
    Feb 2006
    Location
    Ottawa
    Posts
    3,302
    Default Re: Connecting bathtub drain to main vent stack.
    There's nothing wrong with stack venting, but if you're pushing the 5' limit I would add the separate vent as the first picture shows.
    Paul
  4. #3
    Join Date
    Jan 2010
    Location
    Tilbury, Ontario
    Posts
    115
    Paul's advice is good if you're getting close to the 5" limit. Alternatively, since you're using a 4x2 wye, you could switch to 2" trap and pipe from the tub creating additional wet-venting and do it as in the second diagram.
    Mark.
  5. #4
    Join Date
    Apr 2010
    Location
    Toronto
    Posts
    138
    Thanks Mark and Paul. I appreciate the help.
    I've got the 1-1/2 pipe and fittings on hand so if the top drawing is fine, I'll go with that.
    Paul
  6. #5
    Join Date
    Feb 2006
    Location
    UH, Winnipeg!!!
    Posts
    953
    Real Name
    Michael
    They also make a fitting that has the 3" for the toilet as well as a 1 1/2" for the tub, that is what I used in my house, I believe it is called a closet fitting.
    The Bitterness of Poor Quality Lingers Long after the Cheap Price is Forgotten!!!!!
  7. #6
    Join Date
    Apr 2010
    Location
    Toronto
    Posts
    138
    ...just followup question to this; would it be ok to join a wet vent from the vanity sink to the horizontal section of the tub drain with a wye fitting (laying on it's side)?
Similar Threads
  1. Drain Problems
    By bradb in forum Home Improvements
    Last Post: 01-18-2013, 03:00 PM
  2. Connecting two dust collectors together
    By Roy Gilham in forum Dust Collection
    Last Post: 11-03-2011, 12:48 PM
  3. Did I screw up my vent stack???
    By J.P. Rap in forum Home Improvements
    Last Post: 03-09-2011, 09:15 PM
  4. Basement Insulation and Vent Stack
    By georider in forum Home Improvements
    Last Post: 10-05-2010, 11:03 AM
  5. Shop Sub Panel - Main lugs or main breaker?
    By Gary in Waterdown in forum Shop Electrical
    Last Post: 03-23-2009, 07:21 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
